{"product_id":"aim-mxt-strada-10-tft-car-dash-display-with-road-icons","title":"\u003ctc\u003eAim\u003c\/tc\u003e MXT 1.3 سترادا 10\" شاشة TFT للوحة قيادة السيارة مع أيقونات الطريق","description":"\u003cdiv id=\"shopify-section-template--17918277386342__rich_text_bCFQLY\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e\n\u003cdiv class=\"section  section--padding\"\u003e\n\u003cdiv class=\"page-width relative\"\u003e\n\u003cdiv class=\"rich-text  md:text-center text-center relative z-1\"\u003e\n\u003ch2 class=\"heading leading-none title-md\"\u003e\u003cstrong\u003eWhy Choose the MXT 1.3 Strada 10” Dash Display\u003c\/strong\u003e\u003c\/h2\u003e\n\u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e\n\u003cp\u003eThe MXT Strada with road icons is one of the most widely used dash displays on roads around the world. The MXT 1.3 Strada has a 10\" colour TFT display that offers a great visual impact. You can configure the dash to show all the information coming from the ECU, analogue\/digital inputs, predefined math channels and an optional GPS Module.\u003c\/p\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv id=\"shopify-section-template--17918277386342__rich_text_3kEhi6\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e\n\u003cdiv class=\"section  section--padding section--divider\"\u003e\n\u003cdiv class=\"page-width relative\"\u003e\n\u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e\n\u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e\n\u003cdiv class=\"flex flex-col items-center gap-4\"\u003e\n\u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eEasy Connection\u003c\/strong\u003e\u003c\/h2\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e\n\u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e\n\u003cp\u003eThe MXT 1.3 Strada is available with a choice of connections. Choose either the OBDII or K-Line CAN, depending on whether you want to connect to the car's ECU or OBDII port or directly to the ECU through the CAN channel.\u003c\/p\u003e\n\u003cp\u003eYou can sample and display dozens of channels straight from the car’s ECU with only 2 cable connections to the ECU instead of multiple connections to analogue sensors. The sampled data depends on the actual ECU, but will typically include RPM, throttle position (TPS), oil, air, water temperature, oil pressure, battery voltage, speed, gear, and lambda value (air\/fuel ratio). The list of available ECU drivers is over 1,000 and is constantly being updated.\u003c\/p\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv id=\"shopify-section-template--17918277386342__rich_text_cy4Jzy\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e\n\u003cdiv class=\"section  section--padding section--divider\"\u003e\n\u003cdiv class=\"page-width relative\"\u003e\n\u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e\n\u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e\n\u003cdiv class=\"flex flex-col items-center gap-4\"\u003e\n\u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eDigital Outputs\u003c\/strong\u003e\u003c\/h2\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e\n\u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e\n\u003cp\u003eThe MXT 1.3 Strada features 2x 1A-max digital outputs configurable to be activated\/deactivated depending on the value of the analogue\/digital inputs or on the impulses coming from the car’s ECU. This allows you to automatically run external systems, such as switching on\/off additional lights, to activate\/deactivate a cooling fan or circulation pumps when a certain event happens.\u003c\/p\u003e\n\u003cp\u003eWith CAN output, you can send messages directly to an existing CAN network to improve the range of vehicle control possibilities.\u003c\/p\u003e\n\u003cp\u003eTwo analogue camera inputs are also available to switch your display into a\u003cspan\u003e \u003c\/span\u003e\u003ca href=\"https:\/\/www.aimshop.com\/products\/aim-mirror-reversing-camera-for-mx-series-pdm\" title=\"Aim Mirror \u0026amp; Reversing Camera for MX Series \u0026amp; PDM\"\u003emirror camera\u003c\/a\u003e, through a push button command or event management. The camera is sold separately.\u003c\/p\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv id=\"shopify-section-template--17918277386342__rich_text_E8RKHy\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e\n\u003cdiv class=\"section  section--padding section--divider\"\u003e\n\u003cdiv class=\"page-width relative\"\u003e\n\u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e\n\u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e\n\u003cdiv class=\"flex flex-col items-center gap-4\"\u003e\n\u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eDisplay with Road Icons\u003c\/strong\u003e\u003c\/h2\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e\n\u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e\n\u003cp\u003eThe MXT 1.3 Strada has a 10\" TFT high contrast colour display. The visual quality is optimised by the ambient light sensor, which keeps the backlight at the best brightness levels.\u003c\/p\u003e\n\u003cp\u003eRoad icons allow you to apply conditions to the LED icons, such as fuel, engine, oil, lights, indication and more.\u003c\/p\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv id=\"shopify-section-template--17918277386342__rich_text_nAJYLi\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e\n\u003cdiv class=\"section  section--padding section--divider\"\u003e\n\u003cdiv class=\"page-width relative\"\u003e\n\u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e\n\u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e\n\u003cdiv class=\"flex flex-col items-center gap-4\"\u003e\n\u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003ePre-Configured Pages\u003c\/strong\u003e\u003c\/h2\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e\n\u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e\n\u003cp\u003eThe MXT 1.3 Strada shows the RPM scale and all the data you need, like speed, water temperature and oil pressure, lap times and much more. You can customise pages to suit your requirements, including up to four additional fields. Define what data is shown with the end of scale and measure units. Swapping between the pages is easy; just use the push buttons.\u003c\/p\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv id=\"shopify-section-template--17918277386342__rich_text_9enpXA\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e\n\u003cdiv class=\"section  section--padding section--divider\"\u003e\n\u003cdiv class=\"page-width relative\"\u003e\n\u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e\n\u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e\n\u003cdiv class=\"flex flex-col items-center gap-4\"\u003e\n\u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eFlexible Shift Light \u0026amp; Alarms\u003c\/strong\u003e\u003c\/h2\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e\n\u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e\n\u003cp\u003eThe 10 multi-coloured RGB shift lights can be customised to your liking, defining the RPM threshold on analogue or digital inputs, ECU values, expansion values, math channels or optional GPS option. You can choose the conditions and colours, select a solid arm or a flashing one and the flashing frequency. You can also configure an accompanying text message and set the alarm priorities.\u003c\/p\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003ch2 style=\"text-align: center;\"\u003e\n\u003cbr\u003e\u003cbr\u003e\n\u003c\/h2\u003e","brand":"AiM Car","offers":[{"title":"Default Title","offer_id":40297832513638,"sku":"MXT-S-I-CAN\/","price":1455.0,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/product_mxt_strada_road_00_10681841-a89b-495f-81f3-c480f2c52774.webp?v=1770643705","url":"https:\/\/www.aimshop.com\/ar\/products\/aim-mxt-strada-10-tft","provider":"AimShop.com","version":"1.0","type":"link"}
