{"product_id":"aim-pdm-5-6-dash-bracket","title":"Aim PDM 5\" \u0026 6\" Dash Bracket","description":"\u003cp\u003eMount Your System\u003cbr\u003eThe Aim PDM 5” \u0026amp; 6\" Dash Bracket has been designed to securely mount your 5” or 6\" Dash Display in perfect alignment with your PDM08 or PDM32 unit, mounting neatly on the steering column.\u003c\/p\u003e\n\u003cp\u003eWhy Choose the Aim PDM 5” \u0026amp; 6\" Dash Bracket\u003cbr\u003eMade from 2mm thick stainless steel with a raw finish, the bracket provides strength and durability whilst staying lightweight. The Aim PDM 5” \u0026amp; 6” Dash Bracket includes interchangeable mounting components to facilitate the mounting of displays, lap timers, buttons, dash or shift lights as needed, perfect for your setup.\u003cbr\u003eThe PDM Dash Bracket is designed for use with a central hub on the steering column, weld-on tabs, or chassis bolt-on tabs; if you prefer, it can even be fitted without steering wheel mounts. \u003cbr\u003e\u003c\/p\u003e","brand":"AiM Accessories","offers":[{"title":"Default Title","offer_id":32313546145894,"sku":"DISPLAY-6-M","price":25.0,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/product_PDM6_DashMount_00_1.5x.webp?v=1762769387","url":"https:\/\/www.aimshop.com\/ar\/products\/aim-pdm-5-6-dash-bracket","provider":"AimShop.com","version":"1.0","type":"link"}
