AiM SmartyCam 3 GP HD U Bolt Mount For Recording Box 2.1 & 2.2 & 3
SKU: SM-UB-GP-R
- £80.00
- £80.00
- لكل
The SmartyCam 3 GP HD can be installed using the GP HD U bolt mount. It is suitable for SmartyCamGP HD 2.1 & 2.2.
The AiM SmartyCam GP HD U bolt mount is used for mounting the SmartyCam GP HD 2.1 & 2.2 & 3. The mount is designed to mount to a roll bar, railing or tube that have a diameter of between 0.5 to 1.2 inches.
The U bolt clamp has a unique ball and socket system which has been designed to withstand the rigours of motorsport.
The mount is adjustable so you can put the camera in the optimal position, tighten up the mount to secure the camera in position.
U Bolt Mount
Securely attaches to any roll bar, railing or tube with a diameter of 0.5 to 1.2".
AiM SmartyCam GP HD U Bolt Mount For Recording Box
- For use with SmartyCam GP HD 2.1 & 2.2 & 3
- Arm height 90mm ( 3.54 inches )
- U bolt
- 90mm arm
- Clamp base with ball
- Mounting bracket
- Locknuts
- Washers and screws
The SmartyCam 3 GP HD can be installed using the GP HD U bolt mount. It is suitable for SmartyCamGP HD 2.1 & 2.2.Key Features
The AiM SmartyCam GP HD U bolt mount is used for mounting the SmartyCam GP HD 2.1 & 2.2 & 3. The mount is designed to mount to a roll bar, railing or tube that have a diameter of between 0.5 to 1.2 inches. The U bolt clamp has a unique ball and socket system which has been designed to withstand the rigours of motorsport. The mount is adjustable so you can put the camera in the optimal position, tighten up the mount to secure the camera in position.U Bolt Mount
Includes a rubber insert and lock nuts for a secure fit.A solid ball and socket system for optimum positioning.
- U bolt
- 90mm arm
- Mounting bracket
- Locknuts
