تخطي إلى معلومات المنتج
1 من 3
Kawasaki Plug & Play AiM Taipan Motocross ECU Kit
SKU: C-EUC-KIT-KAW
£635.00
£635.00
AiM Taipan ECU Plug & Play Kit For Kawasaki Motocross Bikes
Traction Control
Traction Control Strategy
Launch Control
High Technology 32-bit Core
Engine control requires precision. At 20,000 RPM the Taipan ECU guarantees a precision of 1/10 of degree: this means an accuracy within 0.8 sec for turning the spark ON!
UC Bridge
Tuner License :
Taipan ECU Connections
Aim Handlebar Switch
Below shows a functional diagram of products that can be added to the Taipan ECU:
AiM Taipan ECU Plug & Play Kit for Kawasaki
  • One low side driver (1 A)
  • Power consumption 150 mA
  • n. 1 33 pin male Connector
  • Body: PA6 + 30% glass fiber
  • Waterproof: IP67
  • Weight: 260g
  • Plug & Play ECU for Kawasaki
Traction Control
Launch Control
UC Bridge
The UC Bridge is the connection between the CAN bus of the ECCU and the USB port of your PC. It is available in 2 different licenses : User License : A Taipan ECU comes with some basic maps that already give you better performance than the stock maps. Highly professional tuners all over the world offer specific maps that better fit your requirements, managing, for example, different exhaust, two injectors etc.
Tuner License : With this license, the tuner can create different maps, configurations and strategies designed for the rider's bike. The tuner can then flash them directly onto the ECU or send them via email to allow the rider to download and install them in the ECU.
  • Waterproof: IP67
  • Weight: 260g
Video
