Hyundai i20 N Rally2 BC3N Aim SmartyCam 3 Dual Kit from 2021
SKU: HYUNDAI-Rally-SM3-D
- £1,660.00
- £1,660.00
- لكل
The new SmartyCam 3 Dual saves all your information to a supported SD card for up to 2TB of data, this includes speed, RPM, lap number, gear shifts and many more features. With a built-in data logger running on an external power of 9-15 volts, the new SmartyCam 3 Dual automatically powers on and off in-sync with your engine – and will start/stop recording for you. Analyse your data from a vast range of sources such as GPS track map, vehicle position and speed, lap & split times. Video format is at H.264 1920x1080 pixels, 60 FPS, and the display resolution of 2.4” 240x320 pixels gives your footage crisp condition.
Our quality doesn’t falter, even under the pressure of extreme motorsport conditions such as poor weather, strong vibrations, continuous rain, and high/low temperatures as extreme as -10°C to + 50°C. Our camera is also waterproof (IP65) for extra protection.
Supported Models and years
Hyundai i20 N Rally2 (BC3N)from 2021
The CAN driver developed to communicate with this vehicle, is accessible through the Main_24-Camera connector, a Deutsch DTM06-6P located on the central tunnel next to the fuel tank wall.
Video Output/Streaming
Picture in Picture
Standalone Feature
The SmartyCam 3 Dual provides you with a CAN expansion that connects with many Aim devices such as the Solo 2 DL Laptimer, various Aim Dash Display Loggers, and PDM Dash systems. This is a standard practice within our products, however, we have also equipped the SmartyCam 3 Dual with unterminated CAN connections which allow you to connect the camera to any system as a standalone feature. No matter your vehicle and equipment, with the unterminated connectors you can run the Dual through the CAN/ECU connections of your choosing.
Quality
Anatomy
Higher Storage Capacity
SD cards sold separately.
- CMOS sensor: Global Shutter
- Video Out: 3G-SDI
- External power: 9-15 Volt
- Auto Power ON: Yes
- Auto Power OFF: Yes
- Body: Anodised Aluminium
- Waterproof: IP65-rated to withstand the rigours of motorsport, this kit offers durability and reliability for Hyundai i20 N Rally2 drivers
Channels received by AiM devices configured with Hyundai i20 N Rally2 BC3N protocol are:
Channel Name | Function |
RPM ACVCam | RPM (specific for video recording activation) |
Gear Position | Engaged gear |
Vehicle Speed | Vehicle speed |
Front Brk Press | Front brake pressure |
Rear Brk Press | Rear brake pressure |
Hand Brk Press | Handbrake pressure |
Steering Angle | Steering wheel angle |
Throttle Pedal | Throttle pedal position |
StDrvgMode | Status driving mode |
- SmartyCam 3 Dual
- External Power Cable
- USB-C Cable
- 2 Bullet Cameras
- 2 Co Ax Cables
- Complete CAN / RS232 & Expantion With Ethernet Connection & External Mic Harness
Standalone Feature
Quality
Anatomy
Technical Specifications
- Video Out: 3G-SDI
Hyundai i20 N Rally2 BC3N Protocol
What's In The Box
- SmartyCam 3 Dual
- USB-C Cable
- 2 Bullet Cameras
- 2 Co Ax Cables
