تخطي إلى معلومات المنتج
1 من 5
Hyundai i20 N Rally2 BC3N Aim SmartyCam 3 GP Kit from 2021
SKU: hyundai-rally2-SM3-GP-SM-EM-CAN-4 /
£1,500.00
£1,500.00
Mount Anywhere, Stream Anytime
Enhance your Hyundai i20 N Rally2's performance with the AiM SmartyCam 3 GP Kit, specifically designed for models from 2021.
The all-NEW SmartyCam 3 GP camera has been designed for motorsport with a single purpose:
To provide great videos and supply you with all the information you need.
 SmartyCam 3 GP camera overlays all the data from both GPS and AiM loggers connected to your ECU. Full HD camera system, Video output, CAN connection, USB-C connection, and GPS port are only a few of the features of SmartyCam 3 GP: the power of simplicity.
The new SmartyCam 3 GP saves all your information to a supported micro-SD card for up to 2TB of data, this includes speed, RPM, lap number, gear shifts and many more features. With a built-in data logger running on an external power of 9-15 volts, the new SmartyCam 3 automatically powers on and off with your engine – and will start/stop recording for you. Analyse your data from a vast range of sources such as GPS track map, vehicle position and speed, and lap & split times. The format is at H.264 1920x1080 pixels, 60 FPS, and the display resolution of 2.4” 240x320 pixels gives your footage crisp condition. Our quality doesn’t falter, even under the pressure of extreme motorsport conditions such as poor weather, strong vibrations, continuous rain, and high/low temperatures as extreme as -10°C to + 50°C. Our camera is also waterproof (IP65) for extra protection.
Differences between the Standard and Pro Model
Internal Memory:
SmartyCam 3 GP: Stores video data exclusively on an SD card, supporting capacities up to 2TB.
SmartyCam 3 GP Pro: In addition to SD card storage, it features a 64GB internal EMMC storage that operates on a loop recording basis, overwriting the oldest files when full.
Connectors:
SmartyCam 3 GP: Equipped with standard connectors for power, data, and video output.
SmartyCam 3 GP Pro: Includes two AS Micro Xtra Lite Deutsch connectors, offering enhanced durability and reliability in professional racing environments.
hyundai i20 Rally2 BC3n
Supported Models and years
  • Hyundai i20 N Rally2 (BC3N)
    from 2021
The CAN driver developed to communicate with this vehicle, is accessible through the Main_24-Camera connector, a Deutsch DTM06-6P located on the central tunnel next to the fuel tank wall.
The SmartyCam 3 GP provides you with a CAN expansion that connects with many Aim devices such as the Solo 2 DL Laptimer, various Aim Dash Display Loggers, and PDM Dash systems. This is a standard practice within our products, however we have also equipped the SmartyCam 3 GP with unterminated CAN connections which allow you to connect the camera to any system as a standalone feature. No matter your vehicle and equipment, with the unterminated connectors you can run the GP through your CAN/ECU connections.
The SmartyCam 3 GP includes a global shutter CMOS sensor and a low distortion lens with a field of view of 67°, 84° or 120° covering all areas, its lightweight 200g (battery included) framework infallible in providing you with smooth and effortless footage.
The SmartyCam 3 GP contains a rechargeable lithium battery confined inside its (main) 120.8x80.2x30.9mm (bullet) 24diamx48.2mm body, and using its connectors - 2 Binder 712 female connectors + 2 SMA female connectors (see pinout page) + 1 USB-C - slots right into the back of your dashboard.
Finished with a sleek anodised aluminium coat, the SmartyCam 3 GP is assured to add efficiency, informational data, productivity, and style to your racing. AiM SmartyCam 3 GP has the ability to mount onto many aspects of your vehicle for easier accessibility. Here at AiM, we provide only the best innovations and are constantly and consistently working to better your racing experience.
Generic HD cameras focus too much on pixel numbers resulting in large file sizes. The SmartyCam 3 footage has the same quality as other FHD cameras with smaller files due to H.264 compression system parameters being optimised to a perfect balance between video quality and file size. Choose between three file quality levels: O recording = 4GB (High Quality), 2GB (Normal Quality) or 1.5GB (Lower quality).
SD cards sold separately.
The SmartyCam 3 GP kit seamlessly integrates with the Hyundai i20 N Rally2's ECU, providing real time data overlays for enhanced performance analysis. The SmartyCam 3 GP kit can be connected through the CAN network to our AiM Loggers, MX Series, MXL2, MyChron, Solo2 DL, EVO5 and ECU Bridge.
You can connect more SmartyCam 3 cameras on the same CAN network. The SmartyCam has its configuration and automatically retrieves the data it needs from the network without interfering with the others. You can also synchronize your video and data with the Loggers using Race Studio 3 software.
Upgrade your Hyundai i20 N Rally2 with the AiM SmartyCam 3 GP Kit today and experience unparalleled data insights for yourself!
  • CMOS sensor: Global Shutter
  • Video Out: 3G-SDI
  • External power: 9-15 Volt
  • Connectors: 2 Binder 712 female connectors + 2 SMA female connector (see pinout page) + 1 USB-C
  • Auto Power ON: Yes
  • Auto Power OFF: Yes
  • Body: Anodised Aluminium
  • Dimensions: Main unit 120.8 x 80.2 x 30.9 mm | Bullet camera 24 diam x 46.0 mm (120° lens) | Bullet camera 24 diam x 41.0 mm (67°-84° lens)
  • Bullet Cable Length: From 0.5 m to 4 m (7 lengths available)
  • Weight: Main Body - 320g, Bullet Camera - 45g
  • Waterproof: IP65-rated to withstand the rigours of motorsport, this kit offers durability and reliability for Hyundai i20 N Rally2 drivers
smarty cam 3 sport connectors
 smartycam 3 gp pinout
 smartycam 3 gp Pro pinout
Channels received by AiM devices configured with Hyundai i20 N Rally2 BC3N protocol are:
Channel Name Function
RPM ACVCam RPM (specific for video recording activation)
Gear Position Engaged gear
Vehicle Speed Vehicle speed
Front Brk Press Front brake pressure
Rear Brk Press Rear brake pressure
Hand Brk Press Handbrake pressure
Steering Angle Steering wheel angle
Throttle Pedal Throttle pedal position
StDrvgMode Status driving mode
  • Your choice of either SmartyCam 3 GP or Smartcam 3 GP Pro
  • USB-C Cable
  • 712 5 Pin Male
  • 4M Can Bus + Integrated 3.5 Female Jack For External Microphone Harness
  • 2m CAN Cable
Internal Memory:
Connectors:
    from 2021
Technical Specifications
  • Video Out: 3G-SDI
Hyundai i20 N Rally2 BC3N Protocol
What's In The Box
  • USB-C Cable
  • 712 5 Pin Male
  • 2m CAN Cable
