Link HondaLink - HC20X PlugIn ECU
Link HondaLink PlugIn ECU
The Link HondaLink - HC20X is a G4X PlugIn ECU, offering the latest in engine management technology.
Please Note: This PlugIn ECU features a new 4-pin powered CAN connector and cannot use the old CANPCB cable for CAN connection. Use the CANJST4 (Code 101-0198) cable for connecting CAN devices. This new 4-pin port and cable also provide a protected 12V power supply and ground for powering the CAN devices. The power supply is protected by a self-resetting fuse rated at 3A continuous.
Why Choose the HondaLink PlugIn ECU
The Link HondaLink - HC20X PlugIn ECU fits inside the factory OEM enclosure. Installation is a breeze, with no alteration of the factory wiring loom required for the manual transmission models listed below:
- Honda Integra Type R DC5 2002-2004 with K20A/K20A2/K20A3 Engine
- Acura RSX 2002-2004 with K20A/K20A2/K20A3 Engine
- Honda Civic Type R EP3 2001-2005 with K20A Engine
- Honda Civic Si/SiR 2001-2005 with K20A3
- Honda Civic DX/LX/HX 2001-2005 with D17A1/A2/A3 Engine
- Honda CR-V 2002-2004 with K24A1 Engine
HondaLink PlugIn ECU & Cable
