Same-day dispatch
on orders before 3pm
Finance available
on selected products
First-class support
Aim Solo 2 GPS Lap Timer For Racing and Track Days
£300
The Aim Solo 2 GPS Track Day Lap Timer is a completely automatic Motorsport lap timer. receives the data from two satellite constellations GPS and Glonass, which is a huge step forward since it...
The Aim Solo 2 GPS Track Day Lap Timer is a completely automatic Motorsport lap timer. receives the data from two satellite constellations GPS and Glonass, which is a huge step forward since it is unbelievably faster and more precise than the previous version.
Solo 2
“the most precise and easy way to get lap times”
Solo 2 Screen Colours
Aim Solo 2 screen can be back-lit in one of the seven available colors:
Aim Solo 2 Back Light Colours
Find Your Track Easily and Quickly
Find your track easily and quickly
Solo 2 has a database of more than 2,000 tracks all over the world. As soon as it switches on, the Solo 2 identifies its position, recognises the starting line coordinates of the track and starts sampling lap times.
In the event that the track is not in the database, Solo 2 enters into the auto learning mode, automatically understands the characteristics of the track and gives the lap time anyway.
Even the Predictive Lap Time is Much More Reliable
The Aim Solo 2 configurable RGB LEDs, will give you a clear and fast indication of the comparison with your best lap.
Solo 2 Race Mode Selection
Solo 2 can manage two types of races: Speed races in a closed circuit and Performance tests (0-100 km/h etc.) In each of these configurations, Solo 2 gives the proper information during the test and powerful data review immediately after each session.
Solo Race mode selection
Solo 2 Race Data Recall on Screen
At the end of your test, you can quickly review all the key information on your display.
Solo 2 Wi-Fi Communication with the PC
Wi-Fi connection offers easy, fast connection to PC without connectors nor cables and is the best way to configure your Solo 2, manage the track database and download the data to your PC.
Wi-Fi communication with the PC
    • Display: Graphical
    • Display resolution:128x64 pixels
    • Display pages: Up to 8 freely configurable
    • Back light:7 configurable RGB colors
    • Shift lights/alarm LEDs:10 configurable RGB LEDs
    • Integrated track database:Yes
    • Inertial platform:Internal 3 axis ±5G accelerometer + 3 axis gyro + 3 axis magnetometer
    • Wi-Fi connection: Yes
    • GPS: 10 Hz External power:12 V
    • Memory: 4 GB
    • Pushbuttons: Metallic
    • Dimensions: 98.0x73.7x30.2 mm
    • Weight: 240 g, battery included
    Solo 2 Front View SOLO-2-Rear-View SOLO-2-Side-View
    • Aim Solo 2 GPS Car Racing Trackday Lap Timer
    • Power cable with car lighter socket,
    • Power cable with AC adapter,
    • Mounting bracket with screws,
    • User manual,
    • Software installation CD,
    • Aim sticker
