SAME-DAY DISPATCH
on orders before 3pm
FINANCE AVAILABLE
on selected products
FIRST-CLASS SUPPORT
Aim Solo 2 GPS Track Day Racing Lap Timer and Data Logger
£300
Solo 2 GPS lap timer - for timing, speed and GPS positioning.This little unit is jam packed with race-winning technology. The Solo 2 is the most widely used lap timer...
Solo 2 GPS lap timer - for timing, speed and GPS positioning.This little unit is jam packed with race-winning technology. The Solo 2 is the most widely used lap timer and data logger currently on the market. With features such as real-time GPS speed, lap timing and predictive lap times, the Solo 2 is sure to get more trophies in your cabinet.
Display Parameters
 There can be up to four live parameters simultaneously displayed on the screen at one time, such as vehicle GPS speed and lap number, rolling time, predictive time, and delta time.
LED light Indicators
The fully configurable LED’s can be set to indicate if you are faster or slower on a lap/split-lap
Seven Display Colours
Whether you want to wake up your Fast and Furious fantasies, or there is a genuine need for a different display color, there is a unique color for you.
Different Lap Modes
The Solo 2 comes with two different modes. “Speed mode” is designed for circuit racing, and “Performance mode” is designed for A-B racing such as: hill climbs, drag racing, etc.
Pre-Loaded Track Database
With over 3000 tracks in its database, the Solo 2 is bound to have your track on there. Don’t worry if your track is not in the system. The unit will automatically learn the track via GPS after a few laps. That way, next time you’re out, you can see your previous lap times.
Advanced GPS Technology
The Solo 2 gets its GPS coordinated from 2 different satellites, giving you accuracy down to two-hundredths of a second.
Simple data analysis and upload
                The data can be simply and wirelessly uploaded to your PC via a built-in secured Wi-Fi connection for extended analysis.
RaceStudio 3
                RaceStudio 3 is provided as a free download when you purchase the Solo 2. This is a great platform to modify and view all the data from the unit. It’s so intuitive that even an amateur can use it, but even pro drivers, coaches and engineers use it regularly due to its advanced features.
Optional accessories
    • Display: Graphical
    • Display resolution:128x64 pixels
    • Display pages: Up to 8 freely configurable
    • Back light:7 configurable RGB colors
    • Shift lights/alarm LEDs:10 configurable RGB LEDs
    • Integrated track database:Yes
    • Inertial platform:Internal 3 axis ±5G accelerometer + 3 axis gyro + 3 axis magnetometer
    • Wi-Fi connection: Yes
    • GPS: 10 Hz External power:12 V
    • Memory: 4 GB
    • Pushbuttons: Metallic
    • Dimensions: 98.0x73.7x30.2 mm
    • Weight: 240 g, battery included
    Solo 2 Front View SOLO-2-Rear-View SOLO-2-Side-View
    • Aim Solo 2 GPS Car Racing Trackday Lap Timer
    • Power cable with car lighter socket,
    • Power cable with AC adapter,
    • Mounting bracket with screws,
    • User manual,
    • Software installation CD,
    • Aim sticker
