Aim MXG 1.2 Motorcycle Dash Data logger
£1,925
The 7” MXG 1.2 Motorcycle Dash Data Logger acquires data from your engine ECU, internal accelerometer, internal Gyro...
The 7” MXG 1.2 Motorcycle Dash Data Logger acquires data from your engine ECU, internal accelerometer, internal Gyro and GPS08 Module. Perfect for wider view.
A Wide Range of Data Sources
Performance and data acquired can also be incremented adding up to eight expansion modules. The only difference between the two is the MXS is a compact 5″ display and Aim MXG 1.2 is a 7″ display, a better fit for wide cockpit installations.
CAN Output
With the CAN Output you can send messages directly to an existing CAN network in order to improve the range of vehicle control possibilities.
MXG – A Wide Range of Data Sources
Freely Configurable Pages
You can define all the custom pages you wish, choosing among a wide library of page styles, defining which data to be shown, their end of scale and measure units. Swapping between pages can be managed pushing one or two push buttons.
High Contrast 7″ TFT display
The MXG 1.2 Motorcycle Dash Data logger features a high contrast 7″ TFT display, fully configurable by a dedicated software. An ambient light sensor keeps the back light at optimum brightness levels.
Extra Wide, High Contrast 7″ TFT display
Flexible Alarms
MXG 1.2 features eight configurable RGB alarm LEDs: you choose the conditions, you choose the colours.  Select a solid alarm or flashing one - and the flashing frequency, choose to have an accompanying text message, and set the alarm priorities.
Flexible Alarms
MXG 1.2 Dash View
Two Digital Outputs
Aim MXG 1.2 Motorcycle Dash Data logger features two digital outputs. Each of them can give an output of 1 amp at 12 volts: they can be configured in order to be turned on/off depending on the value of the analogue or digital inputs. They permit to automatically run external systems, i.e. to switch on/off additional lights, to activate/deactivate a cooling fan or circulation pumps, etc. when a certain event happens.
MXG BACK VIEW
info
Two analogue camera inputs are available, to swap your display into a mirror camera, through push button command or event management.
Integrated Shift Light Array
Choose from a host of advanced multicoloured RGB shift light patterns that can be customised to your liking, and for each unique gear when required.
Expand the system, according to your needs
Using the built-in CAN bus, you can add expansion modules to the MXG 1.2 to increment the performance and the data acquired:
GPS08 Module
Thanks to GPS08 Module (included in the kit) and its Race Studio 3 software, you can immediately get laptimes and all data needed for engine tuning as well as for improving driving technique.
Channel Expansion
It permits to add 4 0-5Volt analogue channels for pressure, temperature sensors and potentiometers. Two of these channels can be configured to receive digital inputs like wheel speed.
TC Hub
It adds 4 K thermocouples.
LCU-One CAN
Wide band Lambda controller LCU-One, with Bosch LSU 4.9 probe, providing all Air/Fuel data and lambda value, allows to perfectly tune the carburetion.
SmartyCam HD cameras
The on-board cameras that overlays on videos the data sampled by your logger.
Cockpit view
Race Studio 3 is the heart of your Aim MXG 1.2 Motorcycle Dash Data logger managing all your racing activities.
With Race Studio 3 you can also analyse all data recorded by MXS 1.2 and downloaded to your PC: graphs, histograms and tables will help you study your performance, providing an objective support to avoid mistakes and improve performances
Wi-Fi Connectivity
Makes it even more convenient to configure, calibrate, and download your data wirelessly, using a secure 802.11 WiFi connection: no need to move your PC close to the vehicle anymore, you can do it from your van up to 50 metres away.
Wifi
Get More Data, Win More Races
  • MXG 1.2 Motorcycle Dash Data logger
  • 37 Pin standard harness
  • GPS Module with cable
  • USB cable
  • Software installation CD
MXG IN THE BOX
Display : 7″ TFT
Resolution : 800×480 pixels
Contrast : 1,000:1
Brightness : 700cd/m2 – 1,100 Lumen
Ambient light sensor : Yes
Alarm LEDs : 8 RGB freely configurable
Shift lights : 10 integrated freely configurable RGB LEDs
CAN connections : 3
ECU connections : CAN, RS232 or K-Line
ECU compatibility : + 1,000 industry leading ECUs
Expansion CAN connection : GPS, Channel Expansion, Thermocouple Expansions, Lambda Controller, SmartyCam HD
Analog inputs : 8 fully configurable, max 1,000 Hz each
Digital inputs : 4 Speed inputs, lap signal, coil RPM input
Digital outputs : 2 (1 A max each)
Second CAN : Yes
Wi-Fi connection : Yes
Accelerometer : Internal Three-axial ± 5G + Three-axial Gyroscope+ 3 axis magnetometer
Internal memory : 4 GB
Body : Anodized Aluminum
Pushbuttons : Metallic
Connectors : 2 Motorsport connectors + 1 Binder connector
Power consumption : 400 mA
Dimensions : 237×127.6×26 mm
Weight : 950 g
Waterproof : IP65
MXG Technical 1
MXG Technical 1
MXG Technical 3
The Video In connector allows the connection of two different analog cameras, that may be activated as here down described.
This camera offers a couple of interesting options,
  • The possibility to reverse the image
read more
22 pins harness
Part number: V02573020
Download the tech sheet
22 pins harness with 1 thermocouple
Part number: V02573080
22 pins harness with 2 thermocouples
Part number: V02573160
37 pins harness with 1 thermocouple
Part number: V02573040
37 pins harness with 2 thermocouples
Part number: V02573050
Remote buttons interface
More info
22 pins female Deutsch connector
Part number: 5CN822F00
37 pins female Deutsch connector
Part number: 5CN837F00
SPARE PARTS
37 pins harness
Part number: V02573010
GPS08 Module
More info
USB adapter
Part number: V02573030
USB cable
Part number: X90TMPC002
