SAME-DAY DISPATCH
on orders before 3pm
FINANCE AVAILABLE
on selected products
FIRST-CLASS SUPPORT
MXK10 GEN 5 Kawasaki ZX10R 2016 - 2019 P&P Road Legal Dash with FREE GPS Sensor
£829
AIM MXK10 - GEN 5 Aim MXK10 Kawasaki Ninja ZX10R Plug & Play Road Legal Replacement Dash Display, designed to be compatible with the original Ninja ZX-10R (2016-2019 Models). The MXK10 fits the...
AIM MXK10 - GEN 5
Aim MXK10 Kawasaki Ninja ZX10R Plug & Play Road Legal Replacement Dash Display, designed to be compatible with the original Ninja ZX-10R (2016-2019 Models). The MXK10 fits the original connector and bracket fixing points and includes FREE GPS for automatic track day GPS lap timing.
* Please note: if you want your current milage added to the dash, please state what you want it to be (miles or km) in the notes section of the order.
Kawasaki Ninja ZX-10R Plug & Play Dash Display Aim MXK10 features:
  • Full Plug and Play Replacement Display- No re-wiring needed
  • Dedicated mount bracket
  • GPS module, with bracket and built in world wide track database
  • Data logger for download and analysis using Free Race Studio software
  • Download by USB or WiFi
  • Compatible with the Aim Smartycam Video System
  • May be expanded to add lambda or sensors
Thanks to its high contrast 5’’ TFT display, reading data will always be crystal clear whatever the conditions. Lightweight by design, the MXK10 aluminium body adds to the awesome look of the Kawasaki Ninja ZX-10R, offering a better and more aggressive look.
GPS is an optional fit, included in the kit free, it is not needed to make the system work in any way.
Aim MXK10 Kawasaki Ninja ZX-10R Plug & Play Dash Logger
Get closer with  Aim MXK10
Aim MXK10 is the New Motorcycle Dash Logger designed for the Kawasaki Ninja ZX-10R
Full Plug & Play Road legal Display
The Aim MXK10 is a full Plug & Play dash display, completely compatible with the original Ninja ZX-10R connector and bracket fixing points of your bike.
WATCH THE TUTORIAL
Aim MXK10 is Full Plug and Play
More Clear More Racing
EVERYTHING STILL UNDER COMPLETE CONTROL
EVERYTHING RIGHT UNDER CONTROL
GET THE BEST OUT OF AIM MXK10
A COMPLETE AND USER-FRIENDLY MENU
A WIDE, COMPLETE AND USER-FRIENDLY MENU
LAP TIMING AND DATA LOGGING FOR THE TRACK WITH FREE GPS INCLUDED
EXPANSION AVALIBLE IF NEEDED
MXK10 may even manage a wide range of CAN expansion modules in order to let you acquire data also from suspensions potentiometers, brake pressure sensors, lambda values or tire temperature sensors, in order to gather even more specific data.
EXPANSIONS
 MXK10  Connection Examples
Wi-Fi connectivity and Analysis
 WI-FI CONNECTIVITY AND ANALYSIS
Download all your data via WIFI, for an even more practical usage in your track-day sessions or during your race week-ends.
No more worry about cables that you may have forgotten at home, using a secure 802.11 Wi-Fi connection, all your data can be transferred straight on your PC, ready for analysis using our free software Race Studio 3.
Race Studio 3, offers you analytical access to graphs, histograms and tables which will help you to improve your rider and engine performance.
  • Aim MXK10 Dash, GPS and Bracket
Display: 5” TFT
Resolution: 800×480 pixels
Contrast: 600:1
Brightness: 700cd/m2 – 1,100 Lumen
Ambient light sensor: Yes
Status information LEDs: 6
Shift lights LEDs: 10
CAN connections: 2
ECU connections: Yes
External modules: GPS Module, Channel Expansion, Lambda Controller, SmartyCam HD
Wi-Fi connection: Yes
Internal memory: 4 GB
Body: Anodized Aluminum
Connectors: 1 JAE connector + 2 Binder connectors
Power consumption: 400 mA
Dimensions: 166x97x23 mm
Weight: 530 g
Waterproof: IP65
MXK10 technical
 MXK10 Technical
User guide
Technical sheet
Pictures
Tutorial Video
