SAME-DAY DISPATCH
on orders before 3pm
FINANCE AVAILABLE
on selected products
FIRST-CLASS SUPPORT
Aim MXm Motorcycle Data Logging Dash With GPS
£825
Product code: X87MXM0000 The Aim MXm Motorcycle Data Logging Dash With GPS provides all the info needed by racers. It samples and shows key info like speed, lap times, RPM,...
The Aim MXm Motorcycle Data Logging Dash With GPS provides all the info needed by racers. It samples and shows key info like speed, lap times, RPM, gears, it has a 9 axis inertial platform, multiple math channels and much more. Its strengths are the compactness, which makes MXm perfect to be fit into any kind of motorcycle and its plug-and-play usage is complete but simple. The MXm is the perfect device for both Pro and Amateaur racers.
Aim MXm Compact Dash Data Logger
A wide range of data sources
MXm samples data coming from your ECU, the internal GPS, the inertial platform (accelerometer, gyro and magnetometer), 4 fully configurable analog inputs, 3 digital inputs (2 speed inputs + 1 coil RPM input) and predefined math channels.
For the most demanding, the system can be connected to the Lambda controller and to the SmartyCam HD in order to obtain the full Aim experience.
Integrated shift lights and alarms
MXm features a 5 LED shift light array. Choose from a host of advanced multicolored RGB shift light patterns that can be customized to your liking, and for each unique gear when required. The MXm also features two fully configurable RGB alarm LEDs: you can choose the conditions which turn them on/off, their color,  select a solid alarm - or flashing one - and the flashing frequency.
Two power outputs
MXm features two power outputs that can drain up to 15 A each. The two power outputs can be configured in order  to be turned on/off depending on the value  of the analog or digital inputs.  They permit to automatically run external systems,  i.e. to switch on/off additional lights, to activate/de-activate a cooling fan or circulation pumps, etc. when  a certain event happens.
Two power outputs
Sharp Liquid Crystal
MXm features a high contrast LCD display, with an outstanding black to white ratio. The wide 268x128 pixels graphical LCD offers great flexibility in information display and alerts. An ambient light sensor keeps the backlight at optimum brightness levels.
The screen can be backlit in one of the seven available colors:
The screen can be backlighted in one of the seven available colors:
Data recall on screen
At the end of each session, you can recall the summary of your best laps, with max/min RPM, speed and temperatures.
Data Recall
Choose your own data layout
You can organise this huge quantity of data defining your custom pages, choosing among a wide library of page styles, defining which data to be shown, their end of scale and measure unit.
Wi-Fi connectivity
Makes it even more convenient to configure, calibrate, and download your data wirelessly, using a secure 802.11 WiFi connection: no need to move your PC close to the vehicle anymore, you can do it from your van up to 50 meters away.
Wi-Fi connectivity
MXm Connection Examples
Aim MXm Dash Connection Examples
Race Studio 3 is the true 'engine' of your MXm, as it will manage all your activities related to:
With Race Studio 3 you can create, modify, delete, import and export configurations with all channels, ECU drivers, math channels, display pages, digital outputs, alarms, dhift lights and all the expansions you need. You will also be able to manage the map of all your racing tracks and compare two laps watching the video recorded by SmartyCam HD cameras.
With Race Studio 3 you can also analyze all data recorded by MXm and downloaded to your PC: graphs, histograms and tables will help you study your performance, providing an objective support to avoid mistakes and improve performances.
RS3 Analysis
Download RS3
  • MXm Compact Motorcycle Dash Logger
  • GPS Module with cable,
  • USB cable,
  • 37 pins standard harness,
  • Race Studio 3 software.
Display resolution : 268 x 128 pixels
Backlight : 7 configurable RGB colors
Ambient light sensor : Yes
Shift lights : 5 configurable RGB LEDs
Alarm LEDs : 2 configurable RGB LEDs
CAN connections : 2
ECU connections : CAN, RS232 or K-Line
ECU compatibility : +1,000 industry leading ECUs
GPS : Integrated
External modules : Channel Expansion, Thermocouple Expansion, Lambda Controller, SmartyCam HD
Analog inputs : 4 fully configurable, max 1,000 Hz each
Digital inputs : 2 speed inputs, coil RPM input
Digital outputs : 2 high-side
Inertial platform : Internal 3 axis ±5G accelerometer + 3 axis gyro+ 3 axis magnetometer
Wi-Fi connection : Yes
Internal memory : 4 GB
Body : Glass fiber reinforced Nylon
Pushbuttons : Metallic
Connectors : 37 pins Motorsport connector + 4 pins power connector
Dimensions : 137×88.4×31.9 mm
Weight : 330 g
Waterproof : IP65
MXm Technical
