The Aim MXK10 Kawasaki Ninja ZX10R is a Plug & Play, Road Legal Replacement Dash Display, specifically designed for the original Ninja ZX-10R (2011-2015) models.
AIM MXK10 GEN 4
MXK10-Gen4 is an Aim Dash Logger designed to be easily installed as a full Plug & Play dash logger. The kit is completely compatible with the original connector and with the original bracket fixing points of your 2011-2015 (4th gen) Kawasaki Ninja ZX-10R.
* Please note: if you want your current mileage added to the dash, please state what you want it to be (miles or km) in the notes section of the order.
Features:
  • Full Plug and Play Replacement Display – No re-wiring needed for 2011-2015 (4th gen) Kawasaki Ninja ZX-10R.
  • Dedicated mount bracket
  • GPS module, with bracket and built in world wide track database
  • Data logger for download and analysis using Free Race Studio software
  • Download by USB or WiFi
  • Compatible with the Aim Smartycam Video System
  • May be expanded to add lambda or sensors
Thanks to its high contrast 5’’ TFT display, reading data will always be crystal clear whatever the conditions. Lightweight by design, the MXK10-Gen4  aluminium body adds to the awesome look of the Kawasaki Ninja ZX-10R, offering a better and more aggressive look.
GPS is an optional fit, included in the kit free, it is not needed to make the system work in any way.
MXK10-Gen4 brand new Plug & Play Dash Logger kit specifically designed for Kawasaki Power mode
Full Plug & Play Road legal Display
The Aim MXK10 is a full Plug & Play dash display, completely compatible with the original Ninja ZX-10R connector and bracket fixing points of your bike.
WATCH THE TUTORIAL
MXK10 GEN4 Kit
MXK10 GEN4 KIT
Full Plug & Play
EVERYTHING STILL UNDER COMPLETE CONTROL
  Everything Right Under Control
GET THE BEST OUT OF AIM MXK10
 perfect set-up that fits either your riding-style or the road/track
A Wide, Complete and User-friendly Menu
LAP TIMING AND DATA LOGGING FOR THE TRACK WITH FREE GPS INCLUDED
LAP TIMING AND DATA LOGGING FOR THE TRACK Fully Comaptible Kawasaki racing Kit
EXPANSION AVAILABLE IF NEEDED
MXK10 may even manage a wide range of CAN expansion modules in order to let you acquire data also from suspensions potentiometers, brake pressure sensors, lambda values or tyre temperature sensors, in order to gather even more specific data.
EXPANSIONS
MXK10 may even manage a wide range of CAN expansion modules in order to let you acquire data also from suspensions potentiometers, brake pressure sensors, lambda values or tyre temperature pyrometers, in order to gather even more specific data.
Lambda controller
Wide band Lambda controller LCU-One, with Bosch LSU 4.9 probe, providing all Air/Fuel data and lambda values, allows to verify the behaviour of your ECU.
Channel Expansion
It permits to add four 0-5 Volt analogue channels for pressure, temperature sensors and potentiometers. Two of these channels can be configured to receive digital inputs like wheel speed.
SmartyCam HD Cameras
The on-board cameras that overlays on videos the data sampled by your logger.
CONNECTION EXAMPLES
Connection Examples Wi-Fi connectivity and Analysis
 WI-FI CONNECTIVITY AND ANALYSIS
Download all your data via WIFI, for an even more practical usage in your track-day sessions or during your race week-ends.
No more worry about cables that you may have forgotten at home, using a secure 802.11 Wi-Fi connection, all your data can be transferred straight on your PC, ready for analysis using our free software Race Studio 3.
Race Studio 3, offers you analytical access to graphs, histograms and tables which will help you to improve your rider and engine performance.
Kawasaki Gen4 Kit
Aim MXK10 GEN 4 Dash, GPS and Bracket
    Display : 5” TFT
    Resolution:800x480 pixels
    Contrast: 600:1
    Brightness: 700cd/m2 - 1,100 Lumen
    Ambient light sensor:Yes
    Status information LED's: 6
    Shift lights LED's:10
    CAN connections: 2
    ECU connections: Yes
    External modules: GPS Module, Channel Expansion, Lambda Controller, SmartyCam HD
    Wi-Fi connection: Yes
    Internal memory: 4 GB
    Body: Anodized Aluminium
    Connectors: 1 JAE connector + 2 Binder connectors
    Power consumption: 400 mA
    Dimensions: 166x97x23 mm
    Weight:530 g
    Waterproof:IP65
    4th Generation Technical
    4th Generation Pinout
