Skip to product information
1 of 3
AiM SmartyCam 2.1 HD & SmartyCam 3 Mini Roll Cage Mount
SKU: SM-VB-S
£50.00
£50.00
Powered by Shopify Planet
The SmartyCam HD can be installed using the HD roll cage mount. It is suitable for SmartyCam HD 2.1 & SmartyCam 3.
Fits the SmartyCam camera Universal roll bar fitment
Standard or extended length For SmartyCam HD 2.1 & SmartyCam 3
The AiM mini roll bar mounts have been designed to fit the SmartyCam camera, and enable it to easily be mounted to a roll bar tube.
The mount is manufactured from aluminium with a black anodised finish and designed to withstand the rigours of motorsport use.
Provides an easy method of mounting the SmartyCam to a roll bar.
The supplied jubilee drive clips allow for fitting two different roll cage tube diameters.
Standard or extended lengths are available to choose from.
  • For use with SmartyCam HD 2.1 & SmartyCam 3
  • Roll cage mount (standard or extended version) One supplied
  • 2 x Jubilee clips
Technical sheet Race Studio 3
  • 2 x Jubilee clips
