Aim MX Strada Kit – AimShop.com
Aim MX Strada Kit
SKU: MX-TL-5
Availability: 20 in stock
£834.00
QTY:
Trust Badge
Turn any MX Strada into a full-working logger. Comprising of the Aim Strada Logger, the Data Hub and the GPS 08 Module, the kit will turn any MX Strada into a full-working data logger able to collect data ready to be analysed on Race Studio 3 helping you improve to your driver performance and identifying possible improvements in vehicle setup.
Aim MX Strada Kit
Aim MX Strada Kit
Receiving and reading data while you are driving is not enough anymore?
Then it’s time to step up your game, …with the brand new Aim Strada Kit!
Comprising of the Aim Strada Logger, the Data Hub and the GPS 08 Module, the kit will turn any MX Strada into a full-working data logger able to collect data ready to be analysed on Race Studio 3 helping you improve to your driver performance and identifying possible improvements in vehicle setup. Reliable and easy to install, the Strada Kit is just what you need to make the difference between an above average fast driver into a race winner!
Strada Logger is a small SD Card holder that can be connected via CAN bus to these loggers
Its management is really simple: just connect Strada Logger to your AiM device and data will be saved on the SD card* as well as stored in the logger memory.
No configuration is needed.
In The Box
  • Strada Logger,
  • Four ways Data Hub,
  • GPS08 Module.
  • 4 GB Memory Card
MXS Strada Kit Technical Specs
MX STRADA KIT
Max power consumption: 50 mA
Cable length: 40 cm
SD Card: It supports up to 32 GB
Dimensions: 55.5×78.3×18 mm
Weight: 103 g
Waterproof: IP65
Strada Logger technical drawing
FOUR WAYS DATA HUB
Dimensions: 123x30x23.5 mm
CAN cable length: 40/150 cm
Weight: 97 g
Waterproof: IP65 GPS08
MODULE Dimensions: 64.8×53.2×19.7 mm
Weight: 60.5 g
Four ways Data Hub tech
GPS08 MODULE
Weight: 60.5 g
GPS08 MODULE
