AiM Solo 2 DL + SmartyCam 3 GP GP HD Car Lap Timer Track Day Kit
SKU: SOLO2-K2-SM3-GP
- £2,130.00
- £2,130.00
ULTIMATE TRACK KIT
SmartyCam 3 GP 2.2 & Solo 2 DL Trackday Kit
ECU Connection
The GPS technology provides better reliability from the predictive lap timing function so you can see in real-time how your current lap compares to your best lap. The LEDs are also configurable to give a visual indication of whether you are quicker or slower. You can custom-build the layout of the display to show the data you want to see.
Real-Time Overlay
The SmartyCam 3 GP automatically overlays on your video all the data you need, including speed, RPM, lap number, gear shifts and much more. You can choose the graphical layout to suit your requirements by choosing from the many different overlays available.
CMOS Sensor & Lens
The SmartyCam 3 GP includes a global shutter CMOS sensor and a low distortion lens with a field of view of 67°, 84° or 120° covering all areas, its lightweight 200g (battery included) framework is infallible in providing you with smooth and effortless footage.
Designed for extreme conditions
The SmartyCam 3 GP has been designed to work under the pressure of extreme motorsport conditions such as poor weather, strong and prolonged vibrations, continuous rain and extreme high and low temperatures. The SmartyCam 3 GP is made in machinery moulded aluminium.
Automatic Start/Stop
When you're at the starting grid the last thing you want to be doing is fumbling around with your camera. The SmartyCam 3 GP has been designed with this in mind and switches on/off automatically and starts/stops recording in the same way.
Higher Storage Capacity
AiM SmartyCam 3 GP & Solo 2 DL
- Display: Graphical
- Display Resolution: 238 x 99 pixels
- Shift lights/alarm LEDs: 10 configurable RGB LEDs
- Inertial platform: Internal 3 axis +5G accelerometer + 3 axis gyro
- GPS: 10Hz
- ECU connection: CAN, RS232 or K-Line
- External power: 12V
- Connectors: 1 socket (binder) 712, 5pins, 1 socket (binder) 712 8 pins
- Memory: 4GB
- Battery Type: Rechargeable Lithium
- Dimensions: 98.0 x 73.3 x 30.2mm
- SmartyCam 3 GP
- CMOS sensor: Global Shutter
- Video Out: 3G-SDI
- External power: 9-15 Volt
- Auto Power ON: Yes
- Auto Power OFF: Yes
- Body: Anodised Aluminium
AiM Smartycam 3 GP & Solo 2 DL
- Solo 2 DL
- Mounting Bracket with screws
- Power cable with AC adapter
- Choice of cables:
- CAN/K-Line external power with OBDII connector
- SmartyCam 3 GP
- External CAN cable
- External power cable
- Battery charger with AC power adapter
ULTIMATE TRACK KIT
ECU Connection
Real-Time Overlay
CMOS Sensor & Lens
- GPS: 10Hz
- Memory: 4GB
- SmartyCam 3 GP
- Video Out: 3G-SDI
- Solo 2 DL
- Choice of cables:
- SmartyCam 3 GP
