AiM Solo 2 GPS Track Day Racing Lap Timer
AiM Solo 2 Predictive Lap Timer
The most simple way to get your lap times.
Key Features:
Wi-Fi Communication with the PC
Solo 2 New Track Creation and our Track DatabaseSolo 2 allows you to simply create a new temporary or permanent track layout whether it's a point to point run for rallying or a closed-loop track it can simply be added to the solo 2 and PC database. Simply put, if there is no track already, the Solo 2 will create a new one for you... |
With over 4000 tracks pre-loaded from around the world. As soon as it's switched on the Solo 2 identifies its position. Then once you start to drive it automatically recognises the start line coordinates of the track and will start sampling lap times every time you go past. |
If the tracks not loaded in the database Solo 2 will go into learning mode automatically and will understand the characteristics of the track and give you your lap time its that smart you can then name it and add it to your database for future use as well as adding splits if you wish. |
Unlock your potential |
Our mission is to help enable you to get the most out of your AiM data equipment… whether you are new to racing or a seasoned professional, there is always something new to learn. |
Display: Graphical
Display Resolution: 238x99 Pixels
Display Pages: Up to 8 Freely Configurable
Back Light: 7 Configurable RGB Colours
Shift Lights/Alarm LEDs: 10 Configurable RGB LED's
Integrated Track Database: Yes
Inertial Platform: Internal 3 Axis ±5G Accelerometer + 3 Axis gyro + 3 Axis Magnetometer
Wi-Fi Connection: Yes
GPS: 10 Hz External Power: 12 V
Memory: 4 GB
Battery Type: Rechargeable Lithium
Pushbuttons: Metallic
Dimensions: 98.0x73.7x30.2 mm
Weight: 240 g, Battery Included
Waterproof: IP65
- AiM Solo 2 GPS Car Racing Trackday Lap Timer
- Power Cable with Car Lighter Socket
- Power cable with AC Adapter
- Mounting Bracket with Screws
- User Manual
- Aim Sticker
