Aim Remote Buttons Interface for MXL2, MXG and MXS
£85
Designed to make Aim MXL2, MXG and the MXS easier to use, when system buttons are installed too...
Designed to make Aim MXL2, MXG and the MXS easier to use, when system buttons are installed too far away making it difficult to reach.
Remote Buttons Interface, makes MXL2, MXG and the MXS easier to use when the system buttons can be difficult to push, typically, where the dashboard system is too narrow or too far from your reach.
Basically, it offers 6 contacts to connect to 6 different push buttons. The first four are configured in order to simulate the systems buttons, the fifth is intended to turn ON/OFF the back light and the sixth for resetting the second odometer.
The interface has been designed in order to accept a configuration for changing functionality, in case dedicated features will be required.(see images)
 Click here to download the Pdf file
