SAME-DAY DISPATCH
on orders before 3pm
FINANCE AVAILABLE
on selected products
FIRST-CLASS SUPPORT
Aim MX UTV GPS Digital Dash with Belt Sensor
£450
Product code: X85MXUTV001 Aim MX UTV GPS Digital Dash with Belt Sensor is a gauge designed for being installed on an UTV vehicle. It samples and shows: channels coming from the...
  • channels coming from the vehicle ECU
  • one temperature value that can be belt or, according to the ECU of your vehicle, oil temperature or oil pressure.
  • lap time, with the precision of 1/100 sec and all parameters coming from GPS and Glonass constellations: speed, position, lateral acceleration and time of the day.
The GPS receiver has been tuned for our sport and can thereby stand all lateral and longitudinal accelerations, direction changes and vibrations without problems, always giving a perfect result ten times per second (10 Hz). The MX UTV uses both GPS and Glonass data to compute lap times. In case the track in which you are racing is included in the MX UTV database, it automatically recognizes it, gets the start/finish line and calculates lap times with high precision.
All these data are stored in a huge 4GB internal memory, that can record your data for thousands of hours. You can download the data recorded on your PC using WiFi.
Aim MX UTV
MX UTV is Powered by the Vehicle Battery
Your MX UTV can only be powered by the vehicle battery and is to be installed using the four silent blocks already mounted rear of it.
MX UTV is Expandable
You can connect it via CAN Bus to:
  • SmartyCam HD
  • LCU-One CAN Lambda controller
Wide LCD Display
The wide LCD display has a freely configurable RGB backlight and a light sensor (1) that automatically switches on the back light with low light conditions.
The two RGB alarm LEDs (2) can be switched on with seven different colours, different blinking patterns and custom temperatures thresholds.
Five configurable shift lights (3) help you choosing the best up-shift moment. A very helpful alternative is to use them to indicate the real-time gap between the current lap and the best lap of the session.
Wide LCD Display
Wide LCD Display
MX UTV Back Light Control and Colour
You can set the back light as “ON”, “OFF” or “AUTO”. In this last case the light sensor placed left on the front of your MX UTV switches on/off the backlight according to the ambient light level. In this page you can also change the back light colour choosing among eight different colours.
Race Studio
Race Studio is the heart of your Aim MX UTV managing all your racing activities.
With Race Studio you can create, modify, delete, import and export configurations with all channels, ECU drivers, Math channels, Display Pages, Digital outputs, Alarms, Shift Lights and all the expansions you need. You will also be able to manage the map of all your racing tracks and compare two laps watching the video recorded by SmartyCam HD cameras.
Race Studio
With Race Studio you can also analyse all data recorded by MXG and downloaded to your PC: graphs, histograms and tables will help you study your performance, providing an objective support to avoid mistakes and improve performances.
Race Studio
  • MX UTV
  • CAN + Power cable
  • Single point belt temperature sensor with fixing kit and extension cable
  • Sensor extension cable
Technical specifications
Display resolution: 268×128 pixel
Backlight: 7 configurable RGB colours
Ambient Light sensor: Yes
ShiftLights: 5 freely configurable RGB LED
Alarms LEDs: 2 freely configurable RGB LED
CAN connection: Yes
GPS: Integrated 10Hz GPS+Glonass
Analog Inputs: 1
Wi-Fi connection: Yes
Internal memory: 4Gb
Body: Glass fiber reinforced Nylon
Pushbuttons: Metallic
Connectors: Binder connectors
Dimensions: 137×88,4×31,9 mm
Weight: 330g
Waterproof: IP65
tech drawing
Pinouit
