SAME-DAY DISPATCH
on orders before 3pm
FINANCE AVAILABLE
on selected products
FIRST-CLASS SUPPORT
Aim MXm Data Logging Dash With GPS
£825
The MXM Data Logging Dash provides drivers with all the needed race information at a reasonable price point. Its compact size and simple layout make for a perfect fit in...
The MXM Data Logging Dash provides drivers with all the needed race information at a reasonable price point. Its compact size and simple layout make for a perfect fit in almost any car or bike.
A wide range of data sources
MXM provides the user with information received from several different data sources such as the internal GPS, the ECU, and the built-in inertial platform, just to name a few. For the professional racer, the MXM can be fitted to the Lambda controller and the SmartyCam HD camera for a more involved experience.
Integrated shift lights and alarms
This data logging dash features five fully customizable RGB LED shift lights. In addition, there are two configurable RGB LED alarms that can also be customized to the driver’s specifications.
Two power outputs
Two power outputs are available, and each can supply up to 15 amps each. They can be configured to turn on/off based on the digital or analog values that are set. This allows them to turn on/off certain external sources such as cooling fans or additional lights when a set threshold is met.
Sharp Liquid Crystal
The sharp, high contrast liquid crystal display of the MXM provides the driver with an amazing black to white ratio. The 7 background colors and ambient light display makes sure that you see the screen clearly in any lighting conditions.
The screen can be backlit in one of the seven available colors:
The screen can be backlighted in one of the seven available colors:
Data recall on screen
At the end of each session, you can recall the summary of your best laps, with max/min RPM, speed and temperatures.
Data Recall
Choose your own data layout
You can choose exactly what you want displayed on the screen from our wide array of custom maps in our library. This way you can see exactly the data you want on the screen at any given time.
Wi-Fi connectivity
The secured 802.11 Wi-Fi connectivity makes it easier than ever to configure, calibrate and download the data on to your PC. No more cables are needed!
MXm Connection Examples
Aim MXm Dash Connection Examples
With Race Studio 3 you can create, modify, delete, import and export configurations with all channels, ECU drivers, math channels, display pages, digital outputs, alarms, dhift lights and all the expansions you need. You will also be able to manage the map of all your racing tracks and compare two laps watching the video recorded by SmartyCam HD cameras.
This is where all the collected data goes gets imported, edited, exported, deleted and analyzed. All the different digital and analog channels, alarms, shift lights, etc. can be seen here in neat graphs, histograms and tables. For a more in-depth experience, you can overlap the video from your SmartyCam HD camera with the data to see where improvements can be made.
RS3 Analysis
  • MXm,
  • GPS Module with cable,
  • USB cable,
  • 37 pins standard harness,
  • Race Studio 3 software.
Display resolution : 268 x 128 pixels
Backlight : 7 configurable RGB colors
Ambient light sensor : Yes
Shift lights : 5 configurable RGB LEDs
Alarm LEDs : 2 configurable RGB LEDs
CAN connections : 2
ECU connections : CAN, RS232 or K-Line
ECU compatibility : +1,000 industry leading ECUs
GPS : Integrated
External modules : Channel Expansion, Thermocouple Expansion, Lambda Controller, SmartyCam HD
Analog inputs : 4 fully configurable, max 1,000 Hz each
Digital inputs : 2 speed inputs, coil RPM input
Digital outputs : 2 high-side
Inertial platform : Internal 3 axis ±5G accelerometer + 3 axis gyro+ 3 axis magnetometer
Wi-Fi connection : Yes
Internal memory : 4 GB
Body : Glass fiber reinforced Nylon
Pushbuttons : Metallic
Connectors : 37 pins Motorsport connector + 4 pins power connector
Dimensions : 137×88.4×31.9 mm
Weight : 330 g
Waterproof : IP65
MXm Technical
