Aim MX2E Plug & Play Dash Logger Kit for Lotus Elise / Exige
£1,225
Aim MX2E ‘Plug & Play’ dash logger and cluster kit, specifically designed for Lotus Elise/Exige. Now Available for...
Aim MX2E ‘Plug & Play’ dash logger and cluster kit, specifically designed for Lotus Elise/Exige. Now Available for Elise/Exige (2004 - 2020) models. Easily installed.
MX2E Plug & Play Dash Logger kit specifically designed for Lotus Elise/Exige
MX2E
The plug & play dash logger kit specifically designed for Lotus Elise/Exige
Now available for:
2004 - 2020 models
* Please note: if you want your current mileage added to the dash, please state what you want it to be (miles or km) in the notes section of the order.
* For the 2004 -2007 cars you will also need our adaption harness and need to modify the binnacle.
Full Plug & Play Dash Logger Kit
Featuring an ad-hoc engineered cluster in the kit, with four integrated buttons, MX2E is designed to be easily installed on the Elise and Exige models produced in the years 2011-2019 and it’s fully Plug & Play.
High contrast 6” TFT display
18 integrated LEDS
High contrast 6” TFT display 800x480 pixels
MX2E Features
☐  High contrast 6" TFT display 800x480 pixels  ☐  18 integrated LEDS (10 shiftlights, ☐  6 status information LEDs, 2 turn indicators)
☐  14 digital switch inputs ☐  4 integrated buttons in cluster ☐  CAN bus ECU interface
☐  Rear camera input ☐  Wi-Fi connectivity ☐  Rear camera input
ONE DASH, TWO SOULS...
Two Themes
 ROAD
TRACK
ROAD
ANALOG
ROAD
DIGITAL
DIGITAL
DIGITAL
Four colors, 16 choices
Four colors, 16 choices Integrated Lap Time
On the Track
You can automatically see..
On the Track
and constantly updated by our technicians
constantly updated by our technicians.
After your laps...
After the test
See a Summary of your data, directly from your dash
 After the test
Not enough?
You may expand your MX2E capabilities connecting to:
Channel Expansion
It permits to add four 0-5 Volt analogue channels for pressure, temperature sensors and potentiometers.
Channel Expansion
SmartyCam HD cameras
The on-board cameras that overlays on videos the data sampled by your logger.
Optional inputs for rear camera
IN THE BOX
XA6MXPLEE0
MX2E dash logger with cluster, dedicated GPS Module, screws and washers
Display: 6” TFT
Resolution 800x480 pixels
Contrast 600:1
Brightness 700cd/m2 - 1,100 Lumen
Ambient light sensor Yes
Integrated buttons in cluster 4
Status information LEDs 6
Shift lights LEDs 10
Turn indicators 2
CAN connections 2
ECU connections Yes
External modules GPS Module, Channel Expansion, SmartyCam HD
Wi-Fi connection Yes
Internal memory 4 GB
Body Anodized Aluminum
Connectors 1 Delphi 12040722 connector + 4 Binder 712 connectors
Power consumption 400 mA
Dimensions 191 x 114,2 x 26,4 mm Weight 400 g Waterproof IP65
Technicxal drawing 1
