Aim 7" MXG 1.2 Racing Dash Data logger
£1,925
The 7” MXG 1.2 Dash Data Logger acquires data from your engine ECU, internal accelerometer, internal Gyro and...
The 7” MXG 1.2 Dash Data Logger acquires data from your engine ECU, internal accelerometer, internal Gyro and GPS08 Module. Perfect for wide cockpit installation.
A Wide Range of Data Sources
Performance and data acquired can also be incremented adding up to eight expansion modules. The only difference between the two is the MXS is a compact 5″ display and Aim MXG 1.2 is a 7″ display, a better fit for wide cockpit installations.
CAN Output
With the CAN Output you can send messages directly to an existing CAN network in order to improve the range of vehicle control possibilities.
Freely Configurable Pages
You choose the information you want displayed. There is a library of custom pages for you to choose from, and in case you don’t find one you like, you can make your own page in the RaceStudio 3 program.
High Contrast 7″ TFT display
The high resolution, 7” display has a 1000:1 contrast ratio. On top of that, the built in ambient light sensor will keep the brightness optimal in any weather/lighting conditions.
Flexible Alarms
The MXG offers eight customizable RBG LED alarms. You get to choose the colour, frequency, conditions and the display text. These can be set up to meet your needs in the “Icons Management” tab in RaceStudio 3.
Two Digital Outputs
There are two digital outputs that can be automatically activated depending on the analogue or digital signals from the ECU. For example, they can be used to turn on or off a fan or additional lights when a certain event happens.
MXG BACK VIEW
info
Instantly turn your display into a mirror camera. The 2 camera inputs on the MXG allow the driver to toggle between the gauges and rear-view camera via push-button command.
Integrated Shift Light Array
On top of the eight customizable alarms, the MXG comes with 10 RGB (red, green, blue) LED’s that can be personalised to any colour in any gear. It doesn’t get better than that.
Expand the system, according to your needs
Using the built-in CAN bus, you can add expansion modules to the MXG 1.2 to increment the performance and the data acquired:
GPS08 Module
Thanks to GPS08 Module (included in the kit) and its Race Studio 3 software, you can immediately get lap times and all data needed for engine tuning as well as for improving driving technique.
Channel Expansion
It permits to add 4 0-5Volt analogue channels for pressure, temperature sensors and potentiometers. Two of these channels can be configured to receive digital inputs like wheel speed.
TC Hub
It adds 4 K thermocouples.
LCU-One CAN
Wide band Lambda controller LCU-One, with Bosch LSU 4.9 probe, providing all Air/Fuel data and lambda value, allows to perfectly tune the carburetion.
SmartyCam HD cameras
The on-board cameras that overlays on videos the data sampled by your logger.
Race Studio 3 is the heart of your Aim MXG 1.2 managing all your racing activities.
RaceStudio 3 is a great platform to see and analyze all your data from the ECU and the other various channels. The data is then displayed in graphs, histograms and tables, making is easy to track the changes you make. And best of all, it is completely free!
Wi-Fi Connectivity
Makes it even more convenient to configure, calibrate, and download your data wirelessly, using a secure 802.11 WiFi connection: no need to move your PC close to the vehicle anymore, you can do it from your van up to 50 metres away.
  • Aim MXG 1.2 Racing Dash Data logger
  • 37 Pin standard harness
  • GPS Module with cable
  • USB cable
  • Software installation CD
MXG IN THE BOX
Display : 7″ TFT
Resolution : 800×480 pixels
Contrast : 1,000:1
Brightness : 700cd/m2 – 1,100 Lumen
Ambient light sensor : Yes
Alarm LEDs : 8 RGB freely configurable
Shift lights : 10 integrated freely configurable RGB LEDs
CAN connections : 3
ECU connections : CAN, RS232 or K-Line
ECU compatibility : + 1,000 industry leading ECUs
Expansion CAN connection : GPS, Channel Expansion, Thermocouple Expansions, Lambda Controller, SmartyCam HD
Analogue inputs : 8 fully configurable, max 1,000 Hz each
Digital inputs : 4 Speed inputs, lap signal, coil RPM input
Digital outputs : 2 (1 A max each)
Second CAN : Yes
Wi-Fi connection : Yes
Accelerometer : Internal Three-axial ± 5G + Three-axial Gyroscope+ 3 axis magnetometer
Internal memory : 4 GB
Body : Anodised Aluminium
Pushbuttons : Metallic
Connectors : 2 Motorsport connectors + 1 Binder connector
Power consumption : 400 mA
Dimensions : 237×127.6×26 mm
Weight : 950 g
Waterproof : IP65
MXG Technical 1
MXG Technical 1
MXG Technical 3
The Video In connector allows the connection of two different analogue cameras that may be activated as here down described.
This camera offers a couple of interesting options,
  • The possibility to reverse the image
  • The possibility to enable or disable the parking overlay view
read more
22 pins harness
Part number: V02573020
Download the tech sheet
22 pins harness with 1 thermocouple
Part number: V02573080
22 pins harness with 2 thermocouples
Part number: V02573160
37 pins harness with 1 thermocouple
Part number: V02573040
37 pins harness with 2 thermocouples
Part number: V02573050
Remote buttons interface
More info
22 pins female Deutsch connector
Part number: 5CN822F00
37 pins female Deutsch connector
Part number: 5CN837F00
SPARE PARTS
37 pins harness
Part number: V02573010
GPS08 Module
More info
USB adapter
Part number: V02573030
USB cable
Part number: X90TMPC002
