NEXT DAY DELIVERY
on orders before 3pm
FINANCE AVAILABLE
on selected products
FIRST-CLASS SUPPORT
Aim MXS 1.2 Strada Dash Display Standard Icons
£750
The 5” MXS 1.2 Strada is a Compact Dash Display with Standard Icons. Superb high contrast TFT display with Customisable RGB shift lights for Racing.
The Aim MXS 1.2 Strada Dash Display Standard Icons is the the evolution of MXS Strada which is a  5″ color display with great visual impact. It is configurable to show lap times and all the info coming from the Engine Control Unit like analog/digital inputs, pre-defined math channels and optionally, the GPS08 Module.
MXS 1.2 Strada is available in two versions:
CAN Output
Watch Your Data in Pre-Configured Pages
View data such as RPM, water temperature, oil pressure, and much more through our custom pre-configured pages.
High Contrast TFT Display
The Aim MXS 1.2 Strada shows with RPM scale, all the data you need, like speed, water temperature and oil pressure, lap times and much more. You can choose the custom pages you wish, including up to four additional fields
A wide library of page styles, defining which data to be shown, their end of scale and measured units. Swapping between pages is quite easy with the Aim MXS Strada using the push buttons provided.
Flexible Shift Lights and Alarms
The shift lights can be set to change colours for each gear when needed, while the alarms can be set to display certain colours in certain events. There is a total of 10 shift lights, and 6 alarm lights. Both are high intensity, colour changing RGB LED’s.
CAN Output
With the CAN Output you can send messages directly to an existing CAN network in order to improve the range of vehicle control possibilities.
Two Digital Outputs
The MXS 1.2 Strada features tow digital outputs that can be automatically activated depending on the analog or digital inputs from the ECU. For examples, they can be used to turn on or off a fan or additional lights when a certain event is triggered.
MXS STRADA BACK VIEW
More info
MXS Strada Connection Examples
RaceStudio 3 can be downloaded free of charge and is a great platform to see and analyse all your data from the ECU and the various channels. The data is then displayed in graphs, histograms and tables, making is easy to track and make changes.
With Race Studio 3 you can also analyse all data recorded by MXG and downloaded to your PC: graphs, histograms and tables will help you study your performance, providing an objective support to avoid mistakes and improve performances.
A Wide Range of data sources
MXG is the dashlogger designed to acquire and display data coming from your ECU, the internal accelerometer and gyro, as well as from the GPS08 Module included in the kit, analog/digital inputs and predefined math channels. Performance and data acquired can also be incremented adding up to eight expansion modules. Its 7″ display makes it perfect for wide cockpits installation.
MXS 1.2 Strada Standard With OBD11 Loom. Part. XA3MXSST12A020
MXS 1.2 Strada Standard With CAN ECU Loom. Part.XA3MXSST12A010
  • MXS 1.2 Strada
  • USB cable
  • 14 pin standard wiring
  • 23 pin connector + contacts
  • Software installation CD
MXS Strada Technical Specifications
Display: 5" TFT
Resolution: 800x480 pixels
Contrast: 600:1
Brightness: 700cd/m2 - 1,100 Lumen
Ambient light sensor: Yes
Alarm LEDs: 6 RGB freely configurable
Shift light: 10 integrated freely configurable RGB LEDs
CAN connections: 2
ECU connections: CAN, RS232 or K-Line
ECU compatibility: + 1,000 industry leading ECUs
Expansion CAN connection: GPS, Channel Expansion, TC Hub, Lambda Controller, SmartyCam HD
Analog inputs: 4 fully configurable, max 1,000 Hz each
Digital inputs: 1 speed input, lap signal, coil RPM input
Digital outputs: 1 (1 Amp max)
Second CAN: Yes
Body: Anodized Aluminum
Pushbuttons: Metallic
Connectors: 2 AMP connectors
Dimensions: 169.4x97x23 mm
Weight: 480 g
Power consumption: 400 mA
Waterproof: IP65
Aim MXS Strada tech spec
strada pinout
22 pins harness Part number: V02573020
Download the tech sheet
22 pins harness with 1 thermocouple Part number: V02573080
22 pins harness with 2 thermocouples Part number: V02573160
37 pins harness with 2 thermocouples Part number: V02573050
Remote buttons interface More info
22 pins female Deutsch connector Part number: 5CN822F0
37 pins female Deutsch connector Part number: 5CN837F00
Spare Parts
37 pins harness Part number: V02573010
GPS08 Module
USB adapter Part number: V02573030
USB cable Part number: X90TMPC002
The Video In connector allows the connection of two different analog cameras, that may be activated as here down described.
This camera offers a couple of interesting options,
  • The possibility to reverse the image
  • The possibility to enable or disable the parking overlay view
read more
