Aim Solo 2 GPS Car Racing Track Day Lap Timer – AimShop.com
SKU: SOLO2-K1
Availability: 23 in stock
£360.00
QTY:
Trust Badge
The Aim Solo 2 GPS Car Racing Track Day Lap Timer is a completely automatic motorsport laptimer. receives the data from two satellite constellations GPS and Glonass, which is a huge step forward since it is unbelievably faster and more precise than the previous version.The power ON requires only a few seconds and the lap times are calculated with a max 2/100 sec of tolerance.
Aim Solo 2 Banner
Solo 2
“the most precise and easy way to get lap times”
Aim SOLO 2 GPS Lap Timer
Aim Solo 2 screen can be backlit in one of the seven available colors:
Aim Solo 2 Back Light Colours
Find Your Track Easily and Quickly
Find your track easily and quickly
Solo 2 can rely on a database of more than 3,000 tracks all over the world: as soon as it switches on, Solo 2 identifies its position, recognizes the starting line coordinates of the track and starts sampling lap times. In the event that the track is not in the database then no problem. Solo 2 realises it and enters into the autolearning mode, automatically understands the characteristics of the track and gives the lap time anyway.
Even the Predictive Lap Time is Much More Reliable
The Aim Solo 2 configurable RGB LEDs, will give you a clear and fast indication of the comparison with your best lap.
Solo 2 Race Mode Selection
Solo 2 can manage different types of races, Speed races in a closed circuit, Point to-point races, Regularity, Performance tests (0-100 km/h etc.) In each of these configurations, Solo 2 gives you the correct information during the test and powerful data review immediately after each session.
Solo 2 Race Data Recall on Screen
At the end of your test, you can quickly review all the key information on your display.
Solo 2 Wi-Fi Communication with the PC
Wi-Fi connection is easy and fast without connectors or cables, Simply the best way to configure your Solo 2, to manage the track database and to download the data to your PC.
Solo 2 Wifi Connection
iPhone Connection
COMING SOON!
Use your iPhone for a quick and comfortable  data analysis, for managing the track database and even for an On-Line view of the most important parameters of your Engine  (in case you have chosen the Solo 2 DL).
In the event that the track is not in the database then no problem. Solo 2 realises it and enters into the auto learning mode, automatically understands the characteristics of the track and gives the lap time anyway.
iPhone Connection
SmartyCam HD Connection
SmartyCam HD and Solo 2 Connection
Solo 2 - The perfect connection
Get all the data from your ECU, merge them with the GPS information and transmit everything to the SmartyCam HD, that will show them in graphical overlay in the video.
 ECU Connection
For ECU Connectivity, you will need the Solo 2 DL,
      Technical Specifications
      • Display: Graphical
      • Display resolution:128x64 pixels
      • Display pages: Up to 8 freely configurable
      • Back light:7 configurable RGB colors
      • Shift lights/alarm LEDs:10 configurable RGB LEDs
      • Integrated track database:Yes
      • Inertial platform:Internal 3 axis ±5G accelerometer + 3 axis gyro + 3 axis magnetometer
      • Wi-Fi connection: Yes
      • GPS: 10 Hz External power:12 V
      • Memory: 4 GB
      • Pushbuttons: Metallic
      • Dimensions: 98.0x73.7x30.2 mm
      • Weight: 240 g, battery included
        Solo 2 Front View SOLO-2-Rear-View SOLO-2-Side-View
        Whats in The Box
        • Aim Solo 2 GPS Car Racing Trackday Lap Timer
        • Power cable with car lighter socket,
        • Power cable with AC adapter,
        • Mounting bracket with screws,
        • User manual,
        • Software installation CD,
        • Aim sticker
        Solo2 in the box
        Video
