AiM Solo 2 GPS Track Day Racing Lap Timer and Data Logger
£300
AiM Solo 2 Predictive Lap Timer & Data Logger.  The most simple, way to get your lap times....
Key Features:
  • Rechargeable internal battery
  • 10 configurable RGB LEDs for simple Time +/- reference
  • Full data logger analysis software programme
  • Multiple use modes: Speed, Times & Performance
  • WIFI with security for downloading data
  • Internal 4 GB memory
  • Simple new open or closed track creation
  • Configurable delta and split times
  • Multiple & configurable backlit graphical display
  • Database, with more than 4,000 tracks worldwide
  • Freely configurable display
  • Automatic track Recognition and start / stop
  • Free Race Studio 3 Download
The most precise and easy way to get lap times.
AiM Solo 2 is the most precise GPS lap timer there is with the ability to show you your lap delta live as you drive... receiving data from two satellite constellations from any where on the globe by using GPS and Glonass also giving you a significant improvement in data speed and positioning precision.
Powering on, requires only a few seconds and lap times are calculated with a max 2/100 sec of tolerance.
Solo 2 gives instant speed, timing, splits live data and predictive lap times.
The Solo 2 screen can be back lit in one of the seven available colours:
Predictive Lap timer
The AiM Solo 2 has 10 configurable RGB LEDs which will give you a clear and fast indication of the comparison with your last lap. Predictive page: shows the predicted current lap time in the format you set.
+/- in relation to the Reference Lap Predicted Lap Time
You can custom build the layout of the display to show the information you choose on 4 reconfigurable pages, your data shown in your way see an example below.
Solo 2 Data Recall Modes
Solo 2 can manage two types of data or races:
In each of these configurations Solo 2 gives the complete information during the test with the data ready to view on the solo 2 or Race Studio Analysis software immediately after each race or test session.
Data recall on Screen Data
At the end of your test, you can quickly review all the key information on your display.
Wi-Fi Communication with the PC
With built in WIFI connectivity, you can easily transfer your data securely and quickly to your laptop or computer without cables.
 Solo 2 New Track Creation and our Track Database
Solo 2 allows you to simply create a new temporary or permanent  track layout weather  its a point to point run for rallying or a closed loop track it can simply be added to the solo 2 and PC database.
Simply put, if there is no track already, the Solo 2 will create a new one for you...
With over 4000 tracks pre-loaded from around the world. As soon as its switched on the Solo 2 identifies its position. Then once you start to drive it automatically recognises the start line coordinates of the track and will start sampling lap times every time you go past.
If the tracks not loaded in the database
Solo 2 will go into learning mode automatically and will understand the characteristics of the track and give you your lap time its that smart you can then name it and add it to your database for future use as well as adding splits if you wish.
Unlock your potential
Our mission is to help enable you to get the most out of your AiM data equipment… whether you are new to racing or a seasoned professional, there is always something new to learn.
AiM Solo 2 Product Video
  • Display: Graphical
  • Display Resolution: 238x99 Pixels
  • Display Pages: Up to 8 Freely Configurable
  • Back Light: 7 Configurable RGB Colours
  • Shift Lights/Alarm LEDs: 10 Configurable RGB LED's
  • Inertial Platform: Internal 3 Axis ±5G Accelerometer + 3 Axis gyro + 3 Axis Magnetometer
  • Wi-Fi Connection: Yes
  • GPS: 10 Hz External Power: 12 V
  • Memory: 4 GB
  • Battery Type: Rechargeable Lithium
  • Pushbuttons: Metallic
  • Dimensions: 98.0x73.7x30.2 mm
  • Weight: 240 g, Battery Included
Solo 2 Front View SOLO-2-Rear-View SOLO-2-Side-View
AiM Solo 2 360° Product View
  • AiM Solo 2 GPS Car Racing Trackday Lap Timer
  • Power cable with AC Adapter
  • User Manual
  • Software Installation CD
  • Aim Sticker
