6 Key CAN Bus Keypad
£225
6 Key CAN Switch Keypad. Our CAN bus keypads integrate with your on-board vehicle electronic systems. Features: CAN bus...
Features:
  • CAN bus compatible keyboard
  • IP67 Rated
  • Full customisation
6 Key CAN Keypad.
Designed for the harshest conditions and holds a IP67 rating making it immune to water, mud, soil, sand, oil and chemicals.
Built in LEDs
With built in LEDs to indicate the button state (RGB Colours) and act as a back light for the keypad.
Removable inserts are available for you to build your own keypad the way you want it. These laser etched disc buttons are easily substituted without having to take apart the keypad.
The keypad is able to dialogue with on board systems thanks to its use of CAN.
CAN Keyboard Insert
Your keypad will come with standard blank buttons, so you will need to take a look at the table below and tell us what inserts you want to go with your keypad.
The inserts are numbered at the bottom of each one. Simply email us with the inserts you want and we will send them out with your keypad. Choose six.
Special Keys
Unlock your potential
Our mission is to help enable you to get the most out of your AiM data equipment… whether you are new to racing or a seasoned professional, there is always something new to learn.
AiM Product Video
  • Can bus keypad
  • Waterproof: IP67
    • CAN bus compatible keypad - with blank buttons
    • 6 Inserts you choose to configure your keypad.
    User Guide
    Technical sheet
