8 Channel CAN Wireless Wheel Button Plate
£575
8 Channel Wireless Button Plate. Our best ever 8 channel wireless wheel button plate. Features: CAN Wireless System 8 Push...
Features:
  • CAN Wireless System
  • 8 Push Button Controls
  • CR2 Lithium Battery
CAN 8 Channel Wireless System.
Our new Aim 8 channel wireless system allows you to have push-button controls, whether you have a detachable steering wheel or would just like to devoid the need for unreliable coiled wire connection from your steering wheel to the Dashboard. Using a wireless (RF) connection between wheel transmitter and CAN receiver attached to your AiM device.
8 Channel Wireless Wheel System
Our AiM 8 channel wireless system with CAN Transmitter which bolts straight onto your steering wheel hub and fits all standard bolt patterns on 6 x 70mm, 6 x 74mm and 3 x 50.8mm PCD steering wheels.
There is no need to worry about a flat battery with our smart system as the battery is consistently transmitted to the CANBUS receiver and forwarded to your AiM device. Giving you around 30 days if it needs to be recharged.
Supplied with a standard CR2 Lithium Battery, with a guarantee lifetime of 3 years or 5000 miles road time.
With unrivalled RF communications between our wheel and receiver tested to withstand being subjected to even the harshest EMI that can be generated within your car.
You will never lose connection with your wheel.
The digital pushbuttons can be set to momentary or latching, eg, latching head lights or momentarily flashing them.
Unlock your potential
Our mission is to help enable you to get the most out of your AiM data equipment… whether you are new to racing or a seasoned professional, there is always something new to learn.
AiM Product Video
Transmitter Components
  • Button Plate Front: Matt Black, Textured Acrylic
  • 176 x 154mm
  • Battery Housing: ABS-UL94-V0
  • 54 X 38 X 23mm external
  • CR2 3V Lithium
  • >2000 hours active use
  • Pushbuttons: IP67 momentary
  • Assembly: 8-channel: 265g 176 x 154 x 33mm
  • PCDs Supported: 6 x 70mm, 6 x 74mm, 3 x 50.8mm
  • AiM CAN Wireless Transmitter Assembly
  • Button Plate with 8 Pushbuttons & Covers
  • Battery
  • Decal Sheet
  • 8-Channel Receiver with Connection Harness
  • Installation Instructions
User Guide
Technical sheet
