Infrared Belt Temperature System (IBTS)
£380
The Infrared Belt Temperature System (IBTS). Gauge and an infrared sensor, is a simple, reliable way for monitoring...
The Infrared Belt Temperature System (IBTS). Gauge and an infrared sensor, is a simple, reliable way for monitoring the temperature of the UTV transmission belt.
Installation is quick and easy.
Everything right under control
Gauge Information
The gauge has all the information you need right there. The colour screen shows various information such as battery voltage and belt temperature, while the multi-function buttons allow for easy navigation. On the reverse side you have an input for power, CAN, and the infrared temperature sensor.
Temperature control
You can set two temperature threshold limits, one for a warning and one for the alarm. The temperature level is indicated in three colours. White (all ok), yellow (warning), and red (temperature is over set limit).
 Test history
This little gadget is quite smart. It gives you the option to see the data from the last 25 tests online, given that each session was longer than two minutes but shorter than five hours. This way, you’ll be able to track any changes you’ve made.
Sensor
Gauge
Sensor
1 measurement point
Field of View 12°
Temperature range -60/550°F
Real-time Temperature Tracking
Average Temperature Tracking
Tracks average temperatures over the last 15', 30' or 90' of run-time
Gauge
RGB LED Alert: the LED starts blinking red when temperature exceeds the user defined level
Anti-Glare TFT Display
Anodised aluminum body
Vibration proof
IP65 Water-Resistant
Sensor pinout
Gauge pinout
