Aim EVO 5 Downhill Bike Racing Data Logger
£1,250
The EVO 5 Downhill Bike Racing Data Logger is another data logger option offering a full data logging facility for...
The EVO 5 Downhill Bike Racing Data Logger is another data logger option offering a full data logging facility for improving bike and rider performance.
Comes with Race Studio 3 to fully analyse your riding and bike configuration performance.
A wide range of sources for your data
The EVO 5 Downhill Bike Racing Data Logger samples all the information you need: data coming from your vehicle ECU via CAN, RS232 or K-line, from the internal accelerometers and gyro, from the GPS08 Module included in the kit and from analogue/digital inputs, external expansions as well as predefined math channels. Sensors can be connected to 8 configurable analogue channels, to the RPM input and to 4 wheel speed inputs.
Two digital outputs
The EVO 5 Downhill Bike Racing Data Logger features two digital outputs. The two digital outputs (Dout) are LOW SIDE type (switch to ground): they can be configured in order to be turned on/off depending on the value of the analogue or digital inputs. They permit to automatically run external systems,  i.e. to switch on/off additional lights, to activate/deactivate a cooling fan or circulation pumps etc when a certain event happens.
info
CAN output
With the CAN Output you can send messages directly to an existing CAN network in order to improve the range of vehicle control possibilities.
The Internal SD Card
Allows you to record all possible data you may ever need. The card is protected by a waterproof door equipped with a sensor closing all files when you open it, to prevent any data loss possibility. For faster data downloading, you remove the SD and it is done.
Wi-Fi connection
Configure the system and download your data over a secure 802.11 WiFi connection, even if your car is 100 metres away from you.
Two multi-channel Motorsport connectors
Simple and straightforward, one top quality harness for ALL your connections.
A 37 pin connector for main applications (power, CAN, Aim CAN network, etc.) and a 22 pins connector for additional functions like CAN2, digital outputs.
Expand your EVO5 as much as you need
Add expansion modules via our built-in CAN bus: Channel Expansion
It permits to add 4 0-5 Volt analogue channels for pressure, temperature sensors and potentiometers. Two of these channels can be configured to receive digital inputs like wheel speed.
LCU-One CAN
Wide band Lambda controller LCU-One, with Bosch LSU 4.9 probe, providing all Air/Fuel data and lambda value, allows you to perfectly tune the carburetion.
SmartyCam HD Cameras
The on-board cameras that overlays on videos the data sampled by your logger.
Memory Module
The Memory Module is a small SD Card holder that can be connected via CAN bus to your AiM logger in order to record the data during your tests.
Connection Examples
Aim EVO 5 Downhill Bike Racing Data Logger Connection example
Available displays
To visualise in real time all the data,  EVO5 can be connected to the visor, GS-Dash or to the Formula Steering Wheel 3 - our professional steering wheel for Formula and Sports cars.
Available displays
Download your data to a PC for a professional data analysis
Data recorded by the EVO 5 Downhill Bike Racing Data Logger can be downloaded to PC and analysed with the professional Race Studio Analysis software: graphs, histograms and tables will  help you evaluate your performance, providing an objective support to avoid mistakes and improve your driving technique.  Download your data to a PC for a professional data analysi Download get more data, win more races
  • Integrates with over 500 brands and models of ECU
  • Modular and expandable: 8 analogue inputs, 2 digital inputs, 1 RPM input, 2 digital outputs
  • Supports video integration with AiM SmartyCam HD
  • Supports GPS05 module
  • Internal triaxial G and gyro sensors
  • Removable SD card data recording
    For a correct EVO5 installation it is important to follow some simple rules.
    Carry out CAN, serial or K-line connection only AFTER performing the logger configuration with Race Studio 3. For a correct working of the integrated three-axial accelerometer and gyroscope, EVO5 is to be placed in a central position of the car (ideally in the vehicle's centre of gravity).
    GPS module is not to be positioned under metal or carbon fibre objects, which would greatly reduce the satellite signal quality. Also avoid the positioning close to other antennas, digital cameras or TFT displays. Finally, avoid installing the product with tense cables.
    ECU connection: CAN, RS232, K-Line
    Second CAN: Yes
    External modules connection GPS module, Channel expansion, Lambda controller, SmartyCam HD
    Analog inputs: 8 fully configurable: 0-5V, 0-12V, K thermocouples. Max freq 1 KHz each
    Digital inputs: Coil RPM and 4 speed inputs
    Inertial platform Internal: 3 axis ±5G accelerometer + 3 axis gyro
    WiFi connection: Yes
    Internal memory: 4 Gb
    SD card Internal: up to 128 Gb
    Digital outputs: 2, up to 1 Amp each
    Body: Anodized aluminium
    System dimensions: 114.4x47.2x58.8 mm
    Weight: 300 g
    Waterproof: IP65
    • EVO 5 Downhill Bike Racing Data Logger
    • SD Card
    • Harness
    • GPS 08 Module
    37 Pin Harness - Part number: V02586020
    GPS08 Module
