NEXT DAY DELIVERY
on orders before 3pm
FINANCE AVAILABLE
on selected products
FIRST-CLASS SUPPORT
EVO 5 Downhill Mountain Bike Data Logger Kit
£1,798
The EVO 5 Downhill Racing Logger Kit offers a light weight, full data logging facility for improving bike and rider performance. Suspension Sensor options included.
The Kit includes: Aim EVO 5 Data Logger, 2 x patch leads to connect everything together, 1 x Light weight Lipo Battery and a Hall Speed sensor. There is the additional option of our superb video logger the Smartycam 84 Bullet camera which will show all your data on a video for superb analysis of your performance.
Aim Evo 5 Downhill Bike Racing Data Logger
Aim EVO 5 Car Racing Data Logger
With its compact aluminium body, the Aim EVO 5 data logger can be easily placed on any bike. Its configuration with the new Race Studio 3 software is simple and immediate. Compatibility with Aim visors will be available soon.
A Huge Step Forward
EVO5 is the evolution of the traditional datalogger that, all over the years, has become a standard de facto acquisition system in a huge amount of championships. With its compact aluminium body, EVO5 can be easily placed in any vehicle. Its configuration with the new Race Studio 3 software is simple and immediate.
EVO 5 data logger
A range of sources for your performance data
The EVO 5 Mountain Bike Data Logger samples all the information you need from your bike sensors.
 Sensors
Sensors
Mountain Bike Suspension Potentiometers are available for Front 200mm, and 250mm and for the rear 75mm and 100mm. They are used to measure the displacement between two points using a sensor (linear potentiometer) directly connected to the points of measure. This potentiometer can measure linear displacements like dampers compression or extension and steering rotation measured through the rack displacement
Sensors
Installation details
 more info
    EVO5 GPS08 Module
    GPS 08 Module
    GPS technology represents a true revolution in racing data acquisition.
    Now, thanks to GPS08 Module and Race Studio 3 software,  as soon as you start your track session you can immediately sample lap and split times as well as speed, position and acceleration, all the information needed for engine tuning as well as for improving your driver performance.
    Two satellite systems: top reliability and precision, the GPS08 is more precise than most of the existing GPS systems, as it has been designed to add to the GPS satellite's signal the Global Navigation Satellite (Glonass) system's signal. With an average of almost twenty satellites working in conjunction, GPS08 guarantees a precision and a reliability simply not comparable to the old generation GPS systems.
    Two digital outputs
    EVO5 features two digital outputs.The two digital outputs (Dout) are LOW SIDE
    type (switch to ground): they can be configured in order to be turned on/off depending on the value of the analogue or digital inputs.
    info
    The Internal SD Card
    Allows you to record all possible data you may ever need. The card is protected by a waterproof door equipped with a sensor closing all files when you open it, to prevent any data loss possibility. There is no way to have a faster data downloading: you remove the SD and it is done.
    Wi-Fi connection
    Configure the system and download your data over a secure 802.11 WiFi connection, even if your car is 100 metres away from you.
    Two multi-channel connectors
    Two multi-channel connectors: simple and straightforward, one top quality harness for ALL your connections. A 37 pins connector for main applications (power, CAN, Aim CAN network, etc.) and a 22 pins connector for additional functions like CAN2, digital outputs.
    Expand your EVO5 as much as you need
    EVO5 Sensors
    Download your data to a PC for a professional data analysis
    Data recorded by EVO5 can be downloaded to PC and analysed with the professional Race Studio Analysis software: graphs, histograms and tables will help you evaluate your performance, providing an objective support to avoid mistakes and improve your driving technique.  Download your data to a PC for a professional data analysi
    Technical & Installation
    For a correct EVO5 installation it is important to follow some simple rules.
    Carry out CAN, serial or K-line connection only AFTER performing the logger configuration with Race Studio 3. For a correct working of the integrated three-axial accelerometer and gyroscope, EVO5 is to be placed in a central position of the bike (ideally in the bikes centre of gravity).
    GPS module is not to be positioned under metal or carbon fibre objects, which would greatly reduce the satellite signal quality. Also avoid the positioning close to other antennas, digital cameras or TFT displays. Finally, avoid installing the product with tense cables.
    Specifications:
    ECU connection: CAN, RS232, K-Line
    Second CAN: Yes
    External modules connection GPS module, Channel expansion, Lambda controller, SmartyCam HD
    Analog inputs: 8 fully configurable: 0-5V, 0-12V, K thermocouples. Max freq 1 KHz each
    Digital inputs: Coil RPM and 4 speed inputs
    Inertial platform Internal: 3 axis ±5G accelerometer + 3 axis gyro
    WiFi connection: Yes
    Internal memory: 4 Gb
    SD card Internal: up to 128 Gb
    Digital outputs: 2, up to 1 Amp each
    Body: Anodized aluminium
    System dimensions: 114.4x47.2x58.8 mm
    Weight: 300 g
    Waterproof: IP65
    In The Box
    • EVO 5 Downhill Mountain Bike Racing Data Logger
    • SD Card
    • Harness
    • GPS 08 Module
      Accessories
      37 Pin Harness - Part number: V02586020  GPS08 Module
      User manual ver. 1.02
      Technical sheet ver. 1.06
      Harness for EVO5 ver. 1.01
      Harness of 37 pins Deutsch connector with 1 thermocouple for EVO5 ver. 1.00
      Harness of 37 pins Deutsch connector with 2 thermocouples for EVO5 ver. 1.00
      Pictures
