SAME-DAY DISPATCH
on orders before 3pm
FINANCE AVAILABLE
on selected products
FIRST-CLASS SUPPORT
Aim Mychron 5 Kart Racing Steering Wheel Black
£130
Product code: 3 Hole X07VKM5N / 6 Hole OTK X07VKM5TKN The Aim MyChron 5 Kart Racing Steering Wheel in Black is the ideal complement for your newest MyChron 5. It is...
The Aim MyChron 5 Kart Racing Steering Wheel in Black is the ideal complement for your newest MyChron 5. It is Light weight and ergonomical and it allows you to put your MyChron 5 in the best racing position, which is right in front of you.
Discover the power of MyChron 5, watching all your data in a glance whilst maintaining the best driving position.
Designed with flat bottom and curved top, the MyChron 5 Steering Wheel is made of an anodised aluminium frame covered by chamoised leather. The Nabuk covering on the sides has been added to maximise grip, bringing the total control of the kart in your hands.
Available in two colors (red/black or black) with 3/6 holes.
The MyChron 5 Steering Wheel has been designed to fit all types of kart.
Installing the Mychron 5 Kart Racing Steering Wheel is easy and immediate with the bracket included in the kit.
MyChron5 Steering Wheel mounting details
  • Aim Mychron 5 Kart Racing Steering Wheel
  • bracket.
DIAMETER : 340 mm
WEIGHT : 600 g
COLORS : 2 variants: red/black and black
VERSIONS :2 versions: standard and 6 holes version
CHASSIS :Anodised aluminium
FINISHING :Koram Nabuk + shammy leather
Dimensions
