AiM MyChron5 S 2T Water Temperature Sensor
£420.00
Karting's favourite system just got better.
The all new MyChron5 S 2T is our latest game changing data logger for Kart Racing.
Key Features:
  • 2 temperature sensor inputs
  • Integrated 25Hz GPS
  • Completely configurable pages
  • Free race studio 3 download
AiM MyChron5 S 2T the new and improved latest version of our game changing datalogger / lap timer designed precisely for kart racing has landed.
The GPS frequency has improved from 10 to 25 Hz and the precision accuracy has improved from 5 feet to 2 (1.5 to 45 cm approximately).
A more powerful processor, making the MyChron 5 S 2T 2 times faster than the current MyChron and with much more memory, with more firmware features being developed.
See below for improvements: In blue and yellow the comparison between the old MyChron5 and the new MyChron5 2 TS GPS precision. As you see, the precision dramatically improves passing from 1.5 m to 0.5 m.
In the picture below you can see the improvement we have made, passing from 10 to 25 data per seconds. The yellow dots show the new GPS data.
Integrated GPS
The system takes advantage from an internal wide track database, in order to automatically understand at which track you are at, where and how many are the magnetic strips: without any further sensor or configuration you will automatically get lap times, predictive lap times and split times. GPS data, acquired ten times per second, are of course recorded with other signals in the internal data logger, in order to offer the possibility of a deeper analysis of your performance.
Display Screen
With 7 configurable display colours to choose from, enabling the driver to view clear, easy to read numerical read outs on track such as lap times and lap number, RPM in a configurable scale and 1 temperature value. Once back in the paddock you can scroll through all relevant data on the display: lap times, with best lap indication, max RPM and max temperature value.
The incorporated light sensor makes brightness and contrast ideal in all light conditions.
Choose optimal layout for your data
Lap and split times, best lap, RPM, gear number, track map and much more are shown in pre-configured pages: you will be able to choose the page layout you prefer to better monitor your data.
At the end of your session, you can recall the summary of your three best laps: lap time, max/min RPM, speed and temperature. For your best lap, you will also see splits and best theoretical time.
Shift light & alarm LEDs
 Five RGB shift lights can be configured for each gear, choosing LED colour and RPM threshold values which will turn them on/off. They also allow RPM monitoring in a glance. Even alarms are managed in a very flexible way: you choose the situation that generates the alarm, the LED behaviour (blinking frequency and colour) when the alarm appears and the conditions for its switch-off.
Wireless data download with Wi-Fi connection
Download your data to your PC, look at the OnLine measures, upgrade your firmware, transmit parameters using the well-known Data Key or through fast WiFi connection.
External power or battery charge?
You choose.
MyChron5 S expansions and add-ons
  • LCU-One CAN
    LCU-One Lambda controller, to optimize your engine carburetion.
  • SmartyCam
    SmartyCam on-board camera, for professional recording of your races, with your real-time data overlayed on videos.
  • MyChron Expansion
    The channel multiplier, to check when you brake and accelerate, as well as Power Valve behaviour.
  • Infrared Temperature Controller
    To connect tire temperature sensors to MyChron5S.
  • Data Hub
    The CAN connection multiplier working as an interface between MyChron5S and its peripheral equipments.
  • Sensors
    Temperature, pressure, brake/throttle, steering wheel, speed, RPM sensors.
Turn the device you have to the one you want
Learn more and trade up today >
  • GPS: 25Hz
  • Inertial Platform: Included
  • Wi-Fi Connection: Included
  • Display Resolution: 268 x 128 pixel
  • Ambient Light Sensor: Yes
  • Multifunctional LEDs: 5 RGB LEDs
  • Alarm LEDs: 2 configurable
  • RPM sampling frequency: 50 HZ
  • Body: Glass fibre reinforced nylon
  • Pushbuttons: Metallic
  • Battery: Rechargeable Lithium
  • Memory: 4 GB
  • Dimensions: 137 x 88 30mm
  • Weight: 390g
  • Waterproof: IP67
AiM Mychron 5 S 2T 360° Product View
  • Mychron 5 S 2T
  • Battery Charger with Cable
  • RPM Cable
  • Temperature Sensor
