Skip to product information
1 of 4
AiM Axle Rear Speed Pickup Sensor
SKU: S-S-K-R - X05SNVB301
£70.00
£70.00
All deliveries are carbon neutral
Powered by Shopify Planet
Rear Speed Pick Up Sensor
The AiM wheel speed non-contact sensor for MyChron4 & MyChron5 S.
Key Features:
  • 712 4 pin male connector
  • Speed Sensor
  • Magnetic
  • Free race studio 3 download
Rear Speed Wheel Sensor
The AiM Axle rear speed pickup sensor is suitable for use with the MyChron5 S and MyChron5 S 2T, also including our older models MyChron5 and MyChron4 Kart Dash / Data Loggers.
The rear axle speed sensor has an M10 thread and is supplied with nuts to be mounted on a bracket (not supplied).
It is supplied with a magnetic trigger bolt and is to be installed at 3.5mm from the magnet.
AiM Technologies are committed to supplying, professional engineers with quality Motorsport products. Our cables and accessories are well-engineered and designed for demanding motorsport applications and the demands that racing puts on components. Which makes ours amongst the best in the marketplace today.
Unlock your potential
    Sensor Electrical Characteristics:
    • Power Tension: 6-24 VDC
    • Power Supply: 13.5 mA
    • Output Signal Type: Pulse 0-5 volt
    • Max Current Output: 20 mA
    • Max Operating Frequency: 100kHz
    • Max Sensibility Distance: 20mm
    • Recommended Distance: 10mm
    • Number of Pulses for Wheel Revolution: 1
    Sensor Mechanical Characteristics:
    • Operating Temperature Range: From -20 to +85° C
    • Cable Length: 1700mm
    • Rear Speed Wheel Sensor
    • 3 Nuts
    • 1 Screw
    Key Features:
    • Speed Sensor
    • Magnetic
      Whats In The Box
      • 3 Nuts
      • 1 Screw
