Link Audi TTLink - TTX PlugIn ECU
G4X PlugIn ECUs offer the latest in engine management technology, designed to maximize the potential of your car.
This ECU fits in the factory OEM location. Installation is a breeze, with no alteration of the factory wiring loom required for the models listed below.
The Link G4X ECU TTLink TTX PlugIn Designed for the VWAG PQ34 1.8l Turbo engine with E-Throttle.
This ECU works with manual transmissions only.
Includes an onboard 4 bar or 7 bar MAP sensor.
Suitable Applications:
The engine must be 1.8T
ECU header must have two connectors, 121 pin total
Must be Drive by Wire (E-throttle)
Must be manual transmission
FWD or 4WD (Haldex)
The following vehicles are known to be compatible:
Audi TT - 99-02 - AJQ
VW Beetle - 2005 - AWU
VW Passat - 2000
VW Golf - 2001 - AUM
p to 6D fuel and ignition mapping
Sequential fuel delivery
OEM idle hardware supported
CAN port
USB tuning cable included
Staged injection
Knock with "windowing"
Expansion connector 2
There is no separate expansion connector on the TT Link.
Pin 110 - An Temp 3
Pin 111 - An Volt 10
Pin 112 - DI9
Pin 113 - Ign 6
  • G4X PlugIn ECU
  • Stickers
