Link G4X FuryX WireIn ECU
The FuryX is a premium ECU like the XtremeX, but with added Onboard Digital Wideband Lambda Control. Now on the G4X platform, the FuryX features a faster processor, faster communications & a huge 512 megabytes of data logging!
With 8 injector drives and 6 ignition drives, the FuryX can control up to 3 rotors or 6 cylinders with sequential injection and direct spark, making it an excellent choice for professional-level motorsport or more demanding road car applications.
The added benefit of an Onboard Digital Wideband Lambda Controller means higher accuracy of the unit, plus a simple setup.
The FuryX comes supplied with stickers, a quick start guide, a mounting bracket and a USB tuning cable.
* Requires 'A' & 'B' Looms or 'A' & 'B' Pin Kits, not supplied.
If you are after more inputs, outputs or features, consider the Thunder ECU.
Inputs
8/10* x Digital inputs
4 x Temperature inputs
9 x Analog inputs
2 x Trigger inputs
2 x Knock inputs
1 x LSU 4.9 Wideband lambda sensor input
Outputs
8 x Injection drives
6 x Ignition drivers
10 x Auxiliary outputs^
+5V Sensor power supply
+8V Sensor power supply
Communications
2* x CAN bus
1x Serial (RS232) connection
1x USB tuning connection
Physical
Mass: 680grams
* DI 9 & 10 used by second CAN Bus
Link G4X StormX ECU
  • G4X FuryX ECU
  • USB Tuning Cable
  • Mounting Bracket
  • Stickers
  • Requires “A” & “B” looms or “A” & “B” connector kits. (Sold Separatley)
