AiM Solo 2 GPS Motocross Lap Timer
AiM Solo 2 Predictive Lap Timer & Data Logger.
The most simple way to get your lap times.
Key Features:
Solo 2 gives instant speed, timing, splits live data and predictive lap times. The Solo 2 screen can be back lit in one of the seven available colours:
The AiM Solo 2 has 10 configurable RGB LEDs which will give you a clear and fast indication of the comparison with your last lap. Predictive page: shows the predicted current lap time in the format you set. +/- in relation to the Reference Lap Predicted Lap Time You can custom build the layout of the display to show the information you choose on 4 reconfigurable pages, your data shown in your way see an example below. |
Solo 2 can manage two types of data or races: In each of these configurations Solo 2 gives the complete information during the test with the data ready to view on the Solo 2 or Race Studio Analysis software immediately after each race or test session. |
At the end of your test, you can quickly review all the key information on your Solo 2. |
Wi-Fi Communication with the PC
Solo 2 New Track Creation and our Track DatabaseSolo 2 allows you to simply create a new temporary or permanent track layout whether it's a point to point run for rallying or a closed loop track it can simply be added to the solo 2 and PC database. Simply put if there is no track already the Solo 2 will create a new one for you... |
With over 4000 tracks pre-loaded from around the world. As soon as its switched on the Solo 2 identifies its position. Then once you start to drive it automatically recognises the start line coordinates of the track and will start sampling lap times every time you go past. |
If the tracks not loaded in the database Solo 2 will go into learning mode automatically and will understand the characteristics of the track and give you your lap time its that smart you can then name it and add it to your database for future use as well as adding splits if you wish. |
Unlock your potential |
Our mission is to help enable you to get the most out of your AiM data equipment… whether you are new to racing or a seasoned professional, there is always something new to learn. |
- Display: Graphical
- Display Resolution: 238 x 99 pixels
- Display pages: Up to 8 freely configurable
- Back Light: 7 configurable RGB colours
- Shift Lights / Alarm LEDs: 10 configurable RGB LEDs
- Inertial platform: Internal 3 Axis +5G Accelerometer + 3 Accelerometer + 3 Axis magnetomter
- Wifi: Yes
- GPS: 10 Hz external power: 12V
- Memory: 4GB
- Battery Type: Rechargeable Lithium
- Push buttons: Metallic
- Dimensions: 98.0 x 73.3 x 30.2mm
- Weight: 240g Battery included
- AiM Solo 2 GPS Car Racing Trackday Lap Timer
- Power Cable with Car Lighter Socket
- Power cable with AC Adapter
- Mounting Bracket with Screws
- User Manual
- Aim Sticker
