AiM GS Dash & EVO4S Bike Data Logging Kit
£1,995
The Ultimate GS Dash & EVO4S Data Logging Kit AiM GS Dash & EVO4S data logging kit provides...
AiM GS Dash & EVO4S data logging kit provides you with all the help to improve your performance on the track or road.
Key Features:
  • Small, Flexible, Easy to use
  • GPS08 1.3m included
  • Seven configurable RGB colours
  • Display-268x128 pixel
  • Many options for ECU connection
  • In built accelerometer & gyro sensor
  • One meter patch leads to go with your chosen sensors
Learn more about Plug and Play Kits by manufacturer >
Build your kit your way:
  • Select your Plug & Play lead
  • Select a suspension sensor with patch lead
  • Select a brake pressure sensor with patch lead
EVO4S Data Logging Kit & GS Dash
AiM EVO4S Data Logger with GPS08 with 1.3m cable samples all the information you need. Data coming from the ECU via CAN, RS232 or K-Line, from the internal accelerometer and gyro, from the GPS08 Module which permits automatic and precise lap time calculations.
The GS Dash is a compact, flexible and fully configurable graphical display, showing data sampled by the EVO4S.
A Wide Range of Sources for your Data
 GS Dash swaps among pages showing lap times and data in a 100% customisable way. You choose the data and create the pages displaying up to 8 fields on each.
The RPM and lap time page layout is also available to display RPM Graph, Lap Time and two channels of your choice.
Suspension Potentiometer & Brake Sensor
The suspension potentiometer sensor allows you to measure linear displacements such as, dampers compression or extension, steering rotation measured through the rack displacement.
The brake sensor pressure allows you to detect fluid and air pressures. It offers a high level of reliability and endurance and is protected against the high vibration, shock and high temperatures found in Motorsport.
Below is an image of what your kit may look like depending on which bike cable is required.
Many Sensors can be connected to EVO4S via:
5 analog channels with configurable 12 bit 0-5 Volt, 0-500 mV inputs to thermocouple input, used to sample data coming from temperature, pressure, suspension and other kinds of sensors. 2 speed inputs, which allow you to monitor the different wheel behaviours. 1 RPM input, which manages square wave signals transmitted by the ECU, or pulse signals picked from the coil command ( low voltage).
Internal three-axial accelerometer and gyro sensor. A built in inertial platform lets you have the most powerful system for understanding oversteering, understeering, etc.
Digital output: EVO4S features a 1 amp at 12V digital output. You can configure it in order to turn it on or off depending on the value of the analogue or digital inputs, ECU values, expansion values, GPS information or math channels.
CAN output: With the CAN output you can send messages directly to an existing CAN network in order to improve the range of vehicle control possibilities.
Powerful data analysis: Data recorded by EVO4S can be downloaded to PC and analysed with our race studio 3 software.
Fully Configurable Shift Lights & Alarm LEDs
The GS Dash has five RGB shift lights which can be individually configured for each gear, choosing LED colour and RPM threshold values for their activation.
Alarm LEDs are managed in a very flexible way, you can choose from the situation that generates the alarm, the LED behaviour (blinking frequently and colour) when the alarm appears and the conditions for its switch-off. A warning message can also be shown.
Connection Examples
    GS Dash
    • Display Resolution: 268x x128 pixels
    • Ambient light sensor: Yes
    • Shift Lights: 5 configurable RGB LEDs
    • Display Pages: Fully configurable
    • Pushbuttons: Metallic
    • Dimensions: 127.8 x 82 x 22.2mm
    • Weight: 380g
    AiM EVO4S Bike Data Logging Kit
    • LEDs: 1 system status
    • CAN Connections: 2
    • ECU Compatibility: + 1,000 industry leading ECUs
    • Expansion CAN connections: GPS, Channel Expansions, Thermocouple Expansions, Lambda Controllers, SmartyCam HD
    • Analog inputs: 5 fully configurable, max 1,000 Hz each
    • Digital inputs: 2 speed inputs, lap signal, coil RPM input
    • Digital outputs: 1 (1Amp max)
    • Accelerometer: Internal Three-axial + 5G + Three-axial Gyroscope
    • Internal memory: 4GB
    • Body: Anodised aluminium
    • Connectors: 13 Binder connectors
    • Dimensions: 130 x 35 x 46.6mm
    • Weight: 330g
    • Power consumption: 350 mA
    AiM EVO4S Bike Data Logger Kit
    • EVO4S Data Logger
    • 1.3m GPS08 Module
    • Bracket
    • RPM Output
    • Power Supply 12V
    • USB
    • CAN
    GS Dash
    • GS Dash with spiral cable
    • Installation manual
