AiM MXK10 Kawasaki Ninja ZX-10R (Gen 4 2011-2015) Plug & Play Dash Logger
Home
Motorcycle Dash Display Loggers
AiM MXK10 Gen 4 Kawasaki Ninja ZX10R Road Legal Dash
AiM MXK10 GEN 4 Kawasaki Ninja ZX-10R Plug & Play Road Legal Replacement Dash Display.
Key Features:
MXK10 Kawasaki Ninja ZX-10R Gen 4
- Display: 5" TFT
- Resolution: 800x480 pixels
- Contrast: 600:1
- Ambient light sensor: Yes
- Status information LEDs: 6
- Shift light LEDs: 10
- CAN connections: 2
- ECU connections: Yes
- External modules: GPS Module, Channel Expansion, Lambda Controller, SmartyCam HD
- Wi- Fi connection: Yes
- Internal memory: 4 GB
- Body: Anodised Aluminium
- Connectors: 1 JAE connector + 2 Binder connectors
- Power consumption: 400 mA
- Dimensions: 166X97X23mm
- Weight: 530g
MXK10 Kawasaki Ninja ZX-10R Gen 4 Dash Logger Kit
- MXK10 Dash Logger with screws and washers
- GPS08 Module
- Anodised fixing kit and screws - Bracket
