Skip to product information
1 of 3
Honda CBR 600RR & 1000RR AiM Solo 2 DL & EVO4S Logger Plug & Play Cable
SKU: HON-PP
£67.00
£67.00
Powered by Shopify Planet
Honda CBR 600RR & 1000RR Solo 2 DL & EVO4S Plug & Play Cable
The AiM ECU plug & play cable has been specifically designed for Honda bikes. Allowing easy installation to a Solo 2 DL and an EVO4S Data Logger. With a 7-pin 712 male binder connection.
Honda plug & play cable 7 pin - 712 male binder connection
Honda Plug & Play ECU Cable
The AiM ECU plug & play cable has been specifically designed for the Honda bikes. This plug & play cable can be used for the Solo 2 DL and the EVO4S Data Logger.
CBR 600RR - 2003-2019 CBR 600RR HRC with D11 marked ECU - 2013-2015
CBR 1000RR - 2004-2016 CBR 1000RR HRC - 2014-2016
Example data protocols
  • Below is a pinout drawing for the Honda Solo 2 DL & EVO4S plug & play connection cable
  • Honda CBR 600RR, 1000RR Plug & Play connection cable
