Skip to product information
1 of 3
AiM Solo 2 DL GPS + ECU Motorcycle Track Day Lap Timer
SKU: SOLO2-K4
£630.00
£630.00
Powered by Shopify Planet
Direct ECU data logging
Predictive lap timing
Automatic track recognition
Internal 4 GB memory
Wi-Fi connection
10 configurable RGB LEDs
Choice of connection
Solo 2 DL With ECU Connection
AiM Solo 2 DL is the most precise GPS lap timer with the ability to show lap times live as you drive due to data from two satellite constellations from anywhere globally by using GPS and Glonass, which ultimately gives a significant improvement in data speed and positioning precision.
Start up time is reduced to seconds and lap times are accurate to a tolerance of two-hundredths of a second.
The Solo 2 DL can be connected to the vehicles ECU to obtain various data from the sensors you have fitted to your vehicle. Solo 2 DL manages all the hardware ECU connections and all the communication lines: depending on whether you want to connect to the ECU using the OBDII port or directly to the ECU through the CAN/RS232 channel. If the ECU protocol is not supported connection to the Solo 2 DL to a coil RPM will provide a digital input delivered from square wave signals or pulse signals.
The sampled data you record depends on the actual ECU, typically includes RPM, engine load, throttle position (TPS), oil, air, water temperature, oil pressure, battery voltage, speed, gear and lambda value (air/fuel). The list of ECUs is constantly updated.
Add a SmartyCam HD/GP HD camera to create an even mightier system to help provide you with incredible videos that include all the technical information to help improve your performance.
Solo 2 DL gives instant speed; timing splits live data and predictive lap times.
The GPS technology provides better reliability from the predictive lap timing function, so you can see in real-time how your current lap compares to your best lap. The LEDs are also configurable to give a visual indication of whether you are quicker or slower. You can also build the layout of the display to show the data you want to see.
Data Recall On Screen
Solo 2 DL can be used for circuit racing and point to point or regularity events and performance tests such as 0-60mph. And just like the circuit racing mode, all the data is recorded and can be reviewed immediately after each race or test session.
Solo 2 DL allows you to create a new temporary or permanent track layout. Whether it's a point to point run for rallying or a closed-loop track.
The AiM Solo 2 DL GPS + ECU Motorcycle Track Day Lap Timer is a revolutionary device that is changing the way riders track their performance on the race track. This cutting-edge tool combines a GPS receiver with an ECU interface, providing riders with accurate and detailed data about their lap times, speed, and performance. Whether you're a seasoned pro or just starting out, the AiM Solo 2 DL is a must-have for anyone looking to improve their skills and push their limits on the track.
One of the key features of the AiM Solo 2 DL is its GPS receiver, which allows for extremely accurate lap timing and track mapping. The device is able to track your position on the track with incredible precision, giving you real-time feedback on your lap times and speed. This data can then be analyzed and compared to previous sessions, allowing you to pinpoint areas where you can improve and increase your overall performance on the track.
In addition to its GPS capabilities, the AiM Solo 2 DL also features an ECU interface that allows the device to communicate directly with your motorcycle's engine control unit. This means that the AiM Solo 2 DL can provide you with detailed information about your engine performance, including RPM, throttle position, and gear selection. By analyzing this data alongside your lap times and speed, you can gain valuable insights into how your engine performance is affecting your overall track performance.
Wi Fi Communication With The PC
The Solo 2 DL has integrated Wi Fi. If you want to review your data in more depth, transfer your data securely and quickly onto a laptop or computer up to 50m away without the need for connectors and cables. You can then import the data into the Race Studio 3 software.
Add SmartyCams and a Lambda Control Unit to increase your data performance.
With Race Studio 3 you can create, modify, delete, import and export configurations with all channels, ECU drivers, Math channels, Display Pages, Digital outputs, Alarms, Shift Lights and all the expansions you need. You can also manage the map of all your racing tracks and compare two laps watching the video recorded by SmartyCam HD cameras.
With Race Studio 3 you can also analyse all data recorded by Solo 2 DL and downloaded to your PC: graphs, histograms and tables will help you study your performance, providing objective support to avoid mistakes and improve race times.
  • Display: Graphical
  • Wi-Fi connection: Yes
  • GPS: 10 Hz
  • External power: 12 V
  • Memory: 4 GB
  • Pushbuttons: Metallic
  • Waterproof: IP67
solo 2 dl pinout
  • Solo 2 DL
  • Power cable with AC adapter
  • User manual
  • Choice of power leads available as selected at checkout. Only One Supplied
  • CAN/K-Line external power cable with OBDII connector
  • CAN/RS232 external power cable
  • RPM external power cable (if your vehicle has no ECU)
Wi-Fi connection
  • GPS: 10 Hz
  • Memory: 4 GB
  • Waterproof: IP67
solo 2 dl pinout
  • Solo 2 DL
  • User manual
