Skip to product information
1 of 4
AiM Solo2 DL LCD World SSP300 FIM Kit
SKU: SOLO2-FIM-300
£670.00
£670.00
Powered by Shopify Planet
AiM has developed a specific connection cable for WorldSSP300 bikes ECU for the Solo 2 DL. The cable reads the transmitted data from the ECU via CAN connection.
Predictive lap timing Direct ECU logging
Improved GPS speed & accuracy Up to 8 configurable display pages
10 configurable RGB LEDs 7 different coloured backlights
Integrated GPS Automatic track recognition
AiM has designed a specific connection cable to the WorldSSP 300 bikes ECU for the Solo 2 DL.
This connection cable will allow you to read transmitted data from the ECU via CAN, while at the same time power up the system.
This kit is compatible with:
World SSP 300 Bikes (with MecTronic MKE5 ECU)
Please Note: If you are unsure this connection cable will fit your bike don't hesitate to contact our team. Either by Email, phone or our online chat.
Solo 2 DL LCD World SSP300 FIM Kit
AiM Solo 2 DL raises the bar for GPS lap timers. It can be connected to your bikes ECU to obtain various data from the sensors fitted on your bike.
The GPS technology used receives data from three satellite constellations, GPS, Glonass and Galileo, making a vast improvement in data and position precision. Meaning your start time is reduced to a matter of seconds and your lap times are accurate.
The Solo 2 DL is already pre-loaded with a database of over 4,000 tracks from around the world and is constantly growing.
As soon as the Solo 2 DL is switched on it identifies its position and loads the starting line coordinates ready to begin recording lap times.
If the track your at isn't on the database, the Solo 2 DL will automatically enter an auto-learning mode and begin to build the track layout based on your bikes position and record lap times.
The Solo 2 DL provides better reliability from the predictive lap timing function so you can see, in real-time, how your current lap compares to your best lap.
The LEDs are also configurable to give you a visual indication of whether you are quicker or slower.
The GPS technology provides better reliability from the predictive lap timing function so you can see in real-time how your current lap compares to your best lap. The LEDs are also configurable to give a visual indication of whether you are quicker or slower. You can custom build the layout of the display to show the data you want to see.
Data Recall On Screen
Wi-Fi Communication with PC
These are only some of the items that can be added to our Solo2 DL for incrementing the performance and the data acquired.
With Race Studio 3 you can also analyse all data recorded by Solo2 DL and downloaded to your PC: graphs, histograms and tables will help you study your performance, providing objective support to avoid mistakes and improve performances.
  • Display: Graphical
  • Shift Lights/alarm LEDs: 10 configurable RGB LEDs
  • Inertial Platform: Internal 3 axis +5G accelerometer + 3 axis gyro
  • Wi-Fi Connection: Yes
  • GPS: 10Hz
  • ECU Connection: Yes
  • External Power: 12V
  • Memory: 4 GB
  • Battery Type: Rechargeable Lithium
  • Pushbuttons: Metallic
  • Waterproof: IP67
  • Solo 2 DL
  • Connection Cable for World SSP300 Bike (V02589100)
  • Power Cable with AC Adapter
  • Mounting Bracket with screws
  • GPS: 10Hz
  • Memory: 4 GB
  • Waterproof: IP67
  • Solo 2 DL
