Ducati Panigale 899, 959, 1199, 1199R, 1299 AiM Solo 2 DL Plug & Play Lap Timer Kit
SKU: SOLO2-K-DUC-1
- £710.00
- £710.00
AiM Solo 2 DL is the most precise and simple way to get lap times. Specifically designed for the Ducati this kit will ensure an improvement in your driving performance.
Database with more than 4,000 tracks worldwide | Ducati Panigale ECU connection cable |
This kit has been specifically designed for Ducati Panigale bikes. The kit comes with a cable and bracket for your bike. Connecting the Solo 2 DL to your Ducati Panigale ECU will give you all the engine performance information you need to help improve your driving performance.
The plug & play cable currently fits the following Ducati Panigale bike models:
899 Panigale - 2013-2015 | 959 Panigale - From 2016 |
1199 Panigale - 2012-2014 | 1199R Panigale - 2015-2017 |
1299 Panigale - 2015-2019 |
The Ducati Panigale ECU interface cable provides a plug & play solution for connecting the Solo 2 DL lap timmer to your bike. Please refer to the technical sheet on how to connect the ECU cable to your bike.
Data Recall On Screen
- Display: Graphical
- GPS: 10 Hz
- External power: 12 V
- Memory: 4 GB
Below is the pinout drawing for the Ducati Panigale 899, 959, 1199, 1199R plug & play connection cable.
- Solo 2 DL
- Power cable with AC adapter
- User manual
- AiM Ducati Panigale Connection Cable
- Bracket
- 1 washer
- 1 rubber dowel
AiM Solo 2 DL is the most precise and simple way to get lap times. Specifically designed for the Ducati this kit will ensure an improvement in your driving performance.Key Features :
This kit has been specifically designed for Ducati Panigale bikes. The kit comes with a cable and bracket for your bike. Connecting the Solo 2 DL to your Ducati Panigale ECU will give you all the engine performance information you need to help improve your driving performance.Plug & Play
The plug & play cable currently fits the following Ducati Panigale bike models:899 Panigale - 2013-2015 | 959 Panigale - From 2016 |
The Ducati Panigale ECU interface cable provides a plug & play solution for connecting the Solo 2 DL lap timmer to your bike. Please refer to the technical sheet on how to connect the ECU cable to your bike.The sampled data you record depends on the actual ECU but typically includes RPM, engine load, throttle position (TPS), oil, air, water temperature, oil pressure, battery voltage, speed, gear and lambda value (air/fuel). The list of ECUs is forever growing and being updated.
- GPS: 10 Hz
- Memory: 4 GB
- Solo 2 DL
- User manual
- Bracket
- 1 washer
- 1 rubber dowel
