Skip to product information
1 of 2
AiM Oil/Water Thermocouple Temperature Sensor M5 Type K Motorcycle
SKU: S-T-M5-M-MC
£70.00
£70.00
Powered by Shopify Planet
AiM Oil/Water Thermocouple Temperature Sensor M5 K Type
The AiM oil/water thermocouple temperature sensor with M5 thread allows you to measure oil/water temperature by placing the thermocouple in the cooling system.
Measure oil/water temperature  Thermocouple male fitting
Wide temperature range 2 pins
It can measure the oil/water temperature by being placed in the cooling system. When fitting the sensor ensure it is far away from heat and electromagnetic interference sources like the RPM cable or lap receiver cables.
Temperature range of 0-150°C
Sensor cable length 25cm
  • Temperature working range: 0-150°C
  • Cable sensor length: 25cm
  • Cable Type: Compensated
  • K Type thermocouple
  • AiM Thermocouple M5 Oil/Water Temperature Sensor
