Skip to product information
1 of 4
AiM MXP 1.3 Strada BMW IVA Compliant Kit 6" TFT Display Plug & Play Kit
SKU: MXP-S-BMW-KIT
£1,075.00
£1,075.00
Powered by Shopify Planet
CAN output Configure data
The dash comes with a  23 pin loom which has pre-configured connections for all the relevant electrical items in your vehicle such as oil. temperature, engine temperature, fuel level, sidelights, hazards, front and rear fog, handbrake, main beam, dipped beam and left and right-hand indicator. A speed sensor is also included in the kit to connect to this additional loom.
Digital Outputs
Pre-configured Pages
Flexible Shift Light & Alarms
Camera Inputs
  • Display: 6" TFT
  • CAN Connections: 3
  • Second CAN: Yes
  • Body: Anodized Aluminium
  • Pushbuttons: Metallic
  • Power Consumption: 400 mA
  • Weight: 590g
  • MXP Strada
  • 23 IVA Loom
  • Wheel Speed Sensor
Digital Outputs
Camera Inputs
  • Display: 6" TFT
  • Second CAN: Yes
  • Weight: 590g
  • MXP Strada
  • 23 IVA Loom
