RearMaster Mirror / Reversing Camera – AimShop.com
SKU: MIR-CAM
Availability: 20 in stock
£120.00
QTY:
Trust Badge
Product code: XB1ZCAMHD00
RearMaster Mirror / Reversing Camera for Aim MX Displays and Data Loggers
Physical Connection
The Aim loggers built to manage rear cameras are provided with a female metallic 5 pins Binder connector, placed on the device bottom and labelled as “VIDEO IN” (following image).
Reversing Camera connection
Physical Connection pinout
The Video In connector allows the connection of two different analog cameras, that may be activated as here down described.
  • This camera offers a couple of interesting options:he possibility to reverse the image
  • The possibility to enable or disable the parking overlay view
Please Note: some analog cameras require a 3.3V power. Please, verify before you connect yours to the +Vb output (12V), supplied by the pin3 of the Binder connector .
It has, as most of the analog cameras, a connection through standard RCA connectors (following right image), for which we have developed the patch cables:
Physical connection
Single RearMaster camera (cable length: 5m) ended with:
  • Male metallic 5 pins Binder connector for connection to Aim loggers
  • DC Power Connector (yellow) to be connected to the camera one;
  • Video RCA Connector (red) to be connected to the camera one.
Single RearMaster cameraSingle RearMaster camera
    Double RearMaster camera (cable length: 6m) ended with
    • Male metallic 5pins Binder connector for connection to AiM loggers
    • X2 DC Power Connector (yellow)* to be connected to the camera one
    • X2 Video RCA Connector (red)* to be connected to the camera one.
    * The two DC Power and Video RCA cables couples are respectively 4m and 6m long, in order to allow both front camera and rear camera connection
    Aim offers the same camera with a more reliable Binder connection (Part no. XB1ZCAMHD00; Binder conector pinouts are specified below):
    more reliable Binder 2
    Binder pinouts
    The patch cables available are:
    Single Aim Mirror Camera (6m length) ended with
    • Female metallic 5pins Binder connector for Mirror Camera connection.
    Single Aim Mirror CameraSingle Aim Mirror Camera
      Double Aim Mirror Camera: ended with:
      • X2 female metallic Binder connectors: each one must be used to connect the Mirror Camera (cable lengths 4m – front camera – and 6m – rear camera).
        Configuration through Race Studio 3
        Once the connection has been executed, it is necessary to configure the device, defining a specific event that causes the camera image displaying. For example, if you wish to turn ON the camera when you insert the Reverse Gear, these are the steps to follow:
        • Open Race Studio 3, connect your system via Wi-Fi or USB and create a new configuration (or modify an existing one).
        • The Gear, of course, is supposed to be one of the available channels. It is possible to obtain it
        Through analog sensor, plugging it into one of the device analog channels, which must be configured as expressed on the right (Channels tab). The “Use reverse gear” box must be ticked.
        Through ECU, selecting the compatible protocol with your vehicle ECU from the ECU Stream tab.
        Through ECU
        Open the Trigger Commands tab and click “Add New Command”: select “First Camera Input Page” as a command to activate when the Gear is equal to “R”.
        Trigger Commands
        Settings through Aim device menu
        The camera parameters setting must be executed from the device menu directly, as explained below:
        • Press “MENU/<<” button.
        • Pressing “PREV and “NEXT”, move on the VIDEO IN icon and press “ENTER”.
        • The system offers the possibility to set the image format (PAL or NTSC – according to the camera technical specs), brightness and contrast for each available input.
        camera parameterscamera parameters
          If no key is pressed, after 5 seconds the menu disappears, showing the camera image in live streaming, so that it can be better positioned.
          camera parameters no key is pressed
          Information Sheet
          x
          x
