IVA Compliant ‘Plug and Play’ Car Dash Kit – AimShop.com
SKU: MXS-IVA-S-I-ODB11
Availability: 29 in stock
£995.00
QTY:
Trust Badge
The IVA Compliant ‘Plug and Play’ Car Dash Kit, is a complete Road-Legal Display Solution for OEM, Kit Car Builders and Race Car Builders. The kit has pre-configured, simple wiring connections, for all the relevant electrical items of your vehicle such as Indicators, Lights, Fuel Gauge, Hazard Lights, Handbrake Warning etc
Aim IVA Compliant ‘Plug and Play’ Dash
For OEM and Kit Car Builders!
The key to the system, is the specially designed wiring loom included in the kit, that makes it a ‘Plug & Play’ easy installation of your vehicle electrics. This is all connected to your vehicle’s Engine ECU, to allow easily configurable warning lights and gauges as well as Speed / Gears Revs etc.
The Kit Includes:
  • Road Legal IVA Compliant 5” TFT Colour Display Dash
  • IVA loom
  • Wheel Speed Sensor
Easy Fit?
Once the dash is mounted in the vehicle, any qualified auto electrician will be able connect it all within a day, making the IVA Approved Kit Car Dash Kit, a complete solution for kit car and road car Builders, who need a fully IVA compliant Dash Display for their build. With a pre-configured wiring loom, this offers a simple and cost effective legal way, to get a new digital display in your car.
No ECU?
No Problem, we can take a RPM feed from any Coil or Tacho Signal to make it all come alive.
Aim MXS Strada Plug and Play TFT Dash Display
The IVA Approved, 5″ colour ‘Plug and Play’ Car Dash Display, is used on kit cars all over the world. With its clever ECU link, it acquires data from your vehicle engine, making it relatively easy to fit. When used with our Vehicle interface Module (VIM), it allows for a simple connection to all your lights and sensors.
High Contrast TFT Display
The Aim MXS 1.2 Strada shows with RPM scale, all the data you need, like speed, water temperature and oil pressure, lap times and much more. You can choose the custom pages you wish, including up to four additional fields. A wide library of page styles, defining which data to be shown, their end of scale and measured units. Swapping between pages is quite easy with the Aim MXS Strada using the push buttons provided.
High Contrast TFT DisplayWatch Your Data in Pre-Configured Pages
The MXS 1.2 Strada has a high contrast TFT display and its visual quality is always optimal, as its ambient light sensor keeps the backlight at the best brightness levels. The dash is available in the “Street Icons” version needed by street users (fuel, oil, water temp etc.)
Flexible Shift Lights and Alarms
The ten multi-coloured RGB shift lights on the MXS Strada can be customised to your liking to define the RPM threshold for each single gear. The same flexibility applies to the configurable RGB alarm LED's. You can configure them in order to turn them on/off depending on analog or digital inputs, ECU values, expansion values, math channels or, optionally, GPS information. You choose conditions and colours and you can select a solid alarm or flashing one and the flashing frequency. It is also possible to configure an accompanying text message along with the alarm priorities.
MXS 1.2 Strada is to be configured via Race Studio3: you can create, modify, delete, import and export configurations with all channels, ECU drivers, Math channels, Display Pages, Digital output, Alarms, Shift Lights and all the expansions you need.
In The Box
  • IVA loom
MXS Strada Technical Specifications
Display : 5” TFT
Resolution : 800×480 pixels
Contrast : 600:1
Brightness : 700cd/m2 – 1,100 Lumen
Ambient light sensor : Yes
Alarm LEDs : 6 RGB freely configurable
Shift lights : 10 integrated freely configurable RGB LEDs
CAN connections : 2
ECU connections : CAN, RS232 or K-Line
ECU compatibility : + 1,000 industry leading ECUs
Expansion CAN connection : GPS, Channel Expansion, TC Hub, Lambda Controller, SmartyCam HD
Analog inputs : 8 fully configurable, max 1,000 Hz each
Digital inputs : 1 speed input, coil RPM input
Digital outputs : 1 (1 A max)
Second CAN : Yes
Body : Anodized Aluminum
Pushbuttons : Metallic
Connectors : 2 AMP connectors
Power consumption : 400 mA
Dimensions : 169.4x97x23 mm
Weight : 480 g
Waterproof : IP65
IVA Tech drawing 1
IVA Tech drawing 2
IVA Tech drawing 3
MXS Strada Analog Loom Technical
Fitting
Simple Installation
We have tried to make the installation as simple as possible. The Dash requires power & earth and connecting to the ViM Module. The module has to be connected to your existing Indicators, Lights, etc. using the supplied simple wiring loom. Probably the most complicated part is then using a Multimeter to measure relevant signals to set up items such as your fuel gauge. And that’s it!
Once the dash is mounted in the vehicle (fixing brackets are available) if you prefer, any qualified auto electrician will be able connect it all for you within a day, making the IVA Approved Kit Car Dash Kit a complete solution for Kit Car and Road-Based Vehicle Builders who need a fully IVA compliant Dash Display for their build. Together with the included pre-configured, simple wiring loom the ‘ViM Kit’ offers a highly cost effective legal solution for a digital display in your vehicle.
Download Setup Manual
Customisable Display
Just like modern luxury cars you can choose the Dash display style, from classic round dials to fully digital readouts. Pre-configured layouts of different styles and colours ensure that the Dash is easily configurable using our free RaceStudio 3 software.
You can even switch between the different layouts at any time using the push buttons on the side of the Strada. If the Dash is too far away or you have mounted the display flush into your dashboard, extension cables are available to extend the buttons within easy reach.
Expandable According To Your Needs
As we have a long Motorsport heritage, the MXS Strada Dash can also be connected to other Aim products such as our Data Loggers or Cameras.
MXS Strada ECU Connection
Aim systems acquire data from the ECU of your vehicle. The list of available ECU drivers is constantly updated and upgraded on our support site and are published here. The support site includes over 1,000 different ECU’s both Stock and Racing. They are sorted by manufacturer/vehicle model and for each ECU you find the proprietary communication protocols, including the standard OBDII ones. From a hardware point of view, Aim systems manage the following data lines:
  • CAN
  • RS232
  • K-Line
MXS Strada Analog Digital Inputs
Aim systems analogue inputs are recorded up to 1,000 times per second each. You can connect and monitor all kinds of sensors, like:
  • Ratiometric potentiometers
  • Pressure sensors
  • Thermo-resistances
  • K-type thermocouples
and many others, all your custom sensors included
Aim systems also feature digital inputs:
  • Speed signals – From the ECU, from the GPS and from the wheel sensors.
  • RPM – From the ECU or from a digital input connected to a square wave signal (8 to 50 V) or to a low voltage (from 150 to 400 V) of the coil.
  • Lap signal – Lap and split times are sampled by the GPS or via optical receiver/transmitter
Accessories
22 pins harness Part number: V02573020
Download the tech sheet
22 pins harness with 1 thermocouple Part number: V02573080
22 pins harness with 2 thermocouples Part number: V02573160
37 pins harness with 2 thermocouples Part number: V02573050
Remote buttons interface More info
22 pins female Deutsch connector Part number: 5CN822F0
37 pins female Deutsch connector Part number: 5CN837F00
Spare Parts
37 pins harness Part number: V02573010
GPS08 Module
USB adapter Part number: V02573030
USB cable Part number: X90TMPC002
Loom Pinouts
