MXG Strada 1.2 – AimShop.com
MXG Strada 1.2
SKU: MXG-S-ODB11
Availability: 49 in stock
£1,140.00
QTY:
Trust Badge
The Aim MXG Strada 1.2 Dash Display Standard Icons offers 50% more display area than the 5'' MXS display, in a similar dimension. The dash logger has an integrated shift array, configurable multicolor alarms, drag and drop multi page configuration, Wi-Fi and USB connectivity, GPS Module, inertial platform, analog and digital inputs, digital outputs, Motorsport connectors, 4 GB of internal memory, 1,000Hz per channel sampling and support for over 1,000 ECU connections.
MXG Strada 1.2 samples data coming from your ECU, the GPS Module, the 9 axis inertial platform (accelerometer, gyro and magnetometer), 8 fully configurable analog inputs, 6 digital inputs, predefined math channels and second CAN. Performance and data acquired can also be incremented adding up to eight expansion modules.
Freely configurable pages
You can define all the custom pages you wish, choosing among a wide library of page styles, defining which data to be shown, their end of scale and measure units. Swapping between pages can be managed pushing one or two push buttons.
 High Contrast TFT Display
Aim MXG Strada 1.2 features a high contrast TFT display: its visual quality is always optimal as its ambient light sensor keeps the back light at the best brightness levels. The dash is of course available also in the “Street Icons” version (fuel, oil, water temp etc.)
Flexible alarms & Custom Street Icons
MXG Strada 1.2 features five configurable RGB alarm LED's. You choose the conditions, you choose the colours.  Select a solid alarm or flashing one - and the flashing frequency, choose to have an accompanying text message, and set the alarm priorities. Select then the street icons you need among the wide list you will find in “Race Studio 3 – Icons Management” and set them up the way you prefer or according with your needs. Any of them is fully configurable and if this shouldn’t be enough, you will be able to upload and set up your own customised icons.
Flexible Alarms & Custom Street Icons
Two Digital Outputs
MXG Strada 1.2 features two digital outputs. The two digital outputs (Dout) are LOW SIDE type (switch to ground): they can be configured in order  to be turned on/off depending on the value of the analog or digital inputs. They permit to automatically run external systems, i.e. to switch on/off additional lights, to activate/de-activate a cooling fan or circulation pumps, etc. when a certain event happens.
more info
MXP Strada back
Two analog camera inputs are available, to swap your display into a mirror camera, through pushbutton command or event management.
Integrated shift light array
Choose from a host of advanced multicoloured RGB shift light patterns that can be customised as you like and also for each unique gear when required.
Integrated Shift Light Array
Aim MXG Strada 1.2 Connection Examples
MXG 1.2 Strada Connection Examples
CAN output
With the CAN Output you can send messages directly  to an existing CAN network in order to improve  the range of vehicle control possibilities.
 CAN output
Race Studio 3 is the heart of your MXG Strada 1.2, managing all your racing activities. The Race Studio 3 can create, modify, delete, import and export configurations with all channels, ECU drivers, Math channels, Display Pages, Digital outputs, Alarms, Shift Lights and all the expansions you need. You will also be able to manage the map of all your racing tracks and compare two laps watching the video recorded by SmartyCam HD cameras.
With Race Studio 3 you can also analyse all data recorded by MXG Strada 1.2 and downloaded to your PC: graphs, histograms and tables will help you study your performance, providing an objective support to avoid mistakes and improve performances
Download RS3
Get More Data, Win More Races
Wide range of data sources
MXG Strada 1.2 is the dash logger designed to acquire and display data coming from your ECU, the internal accelerometer and gyro, as well as from the GPS08 Module included in the kit, analog/digital inputs and predefined math channels. Performance and data acquired can also be incremented adding up to eight expansion modules. Its 7″ display makes it perfect for wide cockpits installation.
    GPS Module
    The GPS08 Module (included in the kit) connected via CAN makes lap time calculation and track position analysis very easy. Each Aim memory stores more than 200 world tracks start/finish line coordinates. As soon the dash/logger is switched on, the GPS08 Module will locate its position, identify track-line coordinates and start immediately sampling lap and split time.
    If the track is not included in the database, it is always possible to add the start/finish line coordinates to the MXG Strada 1.2 via PC before going to the track, using the Race Studio 3 – Track Manager software.
    Second CAN
    An innovative feature is the CAN 2 line, managing data coming from your additional modules (i.e. ABS, traction control, infrared temperature sensors and more) This feature meets the requirements of a growing number of racers, as the use of additional modules is becoming quite common in a number of series.
    Internal Accelerometer and Gyro
    The internal three-axial accelerometer and the gyroscope provide a very powerful array of information. These force and motion sensors enable you to quantify the dynamic characteristics of your vehicle. Measuring acceleration forces and gyro rates can assist in determining how to improve your vehicle performances.
    Math Channels
    You immediately get Math Channels values. The dash logger can be configured to display those values (i.e. brake bias, calculated gear) in real time.
    Technical Specifications
    Display: 7” TFT
    Resolution: 800×480 pixels
    Contrast: 1000:1
    Brightness: 700cd/m2 – 1,100 Lumen
    Ambient light sensor: Yes
    Alarm LEDs: 8 configurable RGB LEDs
    Shift lights: 10 configurable RGB LEDs
    CAN connections: 2
    ECU connections: CAN, RS232 or K-Line
    ECU compatibility: + 1,000 industry leading ECUs
    Expansion CAN connection: GPS, Channel Expansion, TC Hub, Lambda Controller, SmartyCam HD
    Analog inputs: 8 fully configurable, max 1,000 Hz each
    Digital inputs: 1 speed input, coil RPM input
    Digital outputs: 1 (1 A max)
    Second CAN: Yes
    Body: Anodized Aluminum
    Pushbuttons: Metallic
    Connectors: 2 AMP connectors + 1 Binder connector
    Power consumption: 400 mA
    Dimensions: 237×127.6×26 mm
    Weight: 950 g
    Waterproof: IP65
    MXG Strada 1.2 Technical info
    In the Box
    1. MXG Strada 1.2
    2. USB cable,
    3. 14 pins standard wiring,
    4. 23 pins connector + contacts,
    5. software installation CD.
      Reversing Camera
      The Video In connector allows the connection of two different analog cameras, that may be activated as here down described.
      This camera offers a couple of interesting options,
      • The possibility to reverse the image
      • The possibility to enable or disable the parking overlay view
      read more
      Accessories
      22 pins harness
      Part number: V02573020
      Download the tech sheet
      22 pins harness with 1 thermocouple
      Part number: V02573080
      22 pins harness with 2 thermocouples
      Part number: V02573160
      37 pins harness with 1 thermocouple
      Part number: V02573040
      37 pins harness with 2 thermocouples
      Part number: V02573050
      Remote buttons interface
      More info
      22 pins female Deutsch connector
      Part number: 5CN822F00
      37 pins female Deutsch connector
      Part number: 5CN837F00
      SPARE PARTS
      37 pins harness
      Part number: V02573010
      GPS08 Module
      More info
      USB adapter
      Part number: V02573030
      USB cable
      Part number: X90TMPC002
