Aim Formula Wheel 3 Powerboat Steering Wheel – Aim Shop - Motorsport Data Loggers, Displays and Laptimers
SKU: FSW3-PB
Availability: 50 in stock
£840.00
QTY:
Trust Badge
The Aim Formula Wheel 3 Powerboat Steering Wheel has been specifically designed for powerboat racing applications and features a small, fully configurable graphical display, showing the data sampled by EVO4S or EVO5 with a precise and clear display.
Aim Formula Steering Wheel 3
"Perfect for Powerboat Racing"
Formula Steering Wheel 3 has been specifically designed for the rigours of motorsport
Aim Formula Steering Wheel 3 has been specifically designed for the rigours of motorsport. It offers the opportunity to see in real time, all the information acquired by EVO4S or EVO5 loggers in a typical “racing” look.
Connection Examples
A flexible display for you data and alerts
The new Formula Steering Wheel 3 Powerboat Steering Wheelfeatures a small, fully configurable graphical display, showing the data sampled by EVO4S or EVO5 with a precise and clear view of the screen data. You can keep constantly under control, lap times and all values coming from the ECU, from the accelerometers and from the GPS (included in EVO4S/EVO5 kits).
A flexible display for you data and alertsIndividually configurable LED’s
Six RGB shift lights can be configured for each gear, choosing LED colour and RPM threshold values which will turn it on/off. Alarms LED’s are managed in a very flexible way: you can choose the event that generates the alarm, the LED behaviour (blinking frequency and colour) when the alarm appears and the conditions for its switch-off. A warning message can also be shown.
Individually configurable LED’sEasy Configuration
Configuration of Shift lights, alarms and customized data pages is intuitive and immediate using the Race Studio 3 software.
Easy Configuration
Up to 9 pages showing the data you want, as you want it
With the Formula Wheel 3 Powerboat Steering Wheel, you can swap among pages showing lap times and data in a 100% customisable way, you just choose your data and create your pages displaying up to 4 fields each. The “RPM and Lap Time” page layout is also available to display RPM Graph, Lap Time and two channels of your choice.
Lap Times
You can visualise the rolling time, or static or predictive lap time (as an absolute value or as a difference vs. the Best Lap).
Lap Times
Highlight Your Performance
A key-data summary is available at the end of each session: the three best laps of the session with their times, min/max speed and min/max RPM’s. In the following page you can also see a list of all the laps of the session.
Switch buttons for external functions
Formula Wheel 3 Powerboat Steering Wheel also features switch buttons to remote 4 functions among the options available in your car, like speed limiter, traction control, neutral, etc. Being electrically isolated from the others, each button operates autonomously.
Optional Paddle Shifts
Formula Wheel 3 Powerboat Steering Wheel features optional paddle shifts.
Robust, Comfortable and Reliable
Aim Formula Wheel 3 Powerboat Steering Wheel is:
  • Robust, for its anodised aluminium chassis.
  • Comfortable and ergonomic: maximum grip is guaranteed by its shape and its finishing with hand-sewn shammy leather.
  • Reliable, with its back-lit display and waterproof structure it can be used in all conditions of light and weather.
Technical Specifications
Dimensions: 270x183x48.2 mm (270x183x67 mm with paddle shifts)
Alarms/Functions: 6 shift light leds, 4 configurable alarm LED's, 4 remote functions
Chassis: Anodised aluminium
Finishing : Hand-sewn shammy leather
  • Formula Wheel 3 Powerboat Steering Wheel
  • CAN cable for logger/ECU Bridge connection
  • Free cables.
Technical sheet ver. 1.00
