{"product_id":"aim-mxg-strada-7-tft-car-dash-display-with-road-icons","title":"Aim MXG 1.3 Strada 7\" TFT Car Dash Display with Road Icons","description":"\u003cstyle\u003e\n    .LandingPage-CatTitle {\n        font-size: 24px;\n        text-align: center;\n      font-weight:600;\n    }\n    .LandingPage-CatSubTitle {\n        font-size: 22px;\n        text-align: center;\n      margin:0;\n      font-weight:600;\n    }\n    .TextBoxes {\n        font-size: 20px;\n        line-height: 32px;\n        text-align: center;\n    }\n  .features_container {\n  max-width: 1200px;\n      margin: 0 auto;\n padding-top: 20px !important;\n      padding-bottom: 20px !important;\n}\n\n.features_title {\n  font-size: 32px;\n  font-weight: 700;\n  text-align: center;\n  margin-bottom: 40px;\n  color: #333;\n  text-transform: uppercase;\n  letter-spacing: 1px;\n}\n\n.features_grid {\n  display: grid;\n  grid-template-columns: repeat(2, 1fr);\n  gap: 20px;\n  background-color: #f9f9f9;\n  padding: 30px;\n  border-radius: 8px;\n  box-shadow: 0 2px 10px rgba(0, 0, 0, 0.05);\n}\n\n.features_item {\n  font-size: 16px;\n  color: #555;\n  text-align: center;\n  padding: 15px;\n  background-color: #fff;\n  border: 1px solid #eee;\n  border-radius: 4px;\n  transition: transform 0.2s ease, box-shadow 0.2s ease;\n}\n    @media (max-width: 768px) {\n        .LandingPage-CatTitle {\n            font-size: 22px;\n        }\n        .LandingPage-CatSubTitle {\n            font-size: 20px;\n        }\n        .TextBoxes {\n            font-size: 18px;\n            line-height: 32px;\n        }\n    }\n\n\/* Mobile adjustments *\/\n@media (max-width: 600px) {\n  .features_grid {\n    grid-template-columns: 1fr; \/* Single column on mobile *\/\n    padding: 20px;\n  }\n\n  .features_title {\n    font-size: 24px;\n    margin-bottom: 30px;\n  }\n\n  .features_item {\n    font-size: 14px;\n    padding: 12px;\n  }\n}\n    \u003c\/style\u003e  \u003cdiv id=\"shopify-section-template--17916592291942__rich_text_bCFQLY\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e  \u003cdiv class=\"section  section--padding\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"rich-text  md:text-center text-center relative z-1\"\u003e  \u003ch2 class=\"heading leading-none title-md\"\u003e\u003cstrong\u003eHvorfor vælge MXG 1.3 Strada 7” instrumentbrætdisplay\u003c\/strong\u003e\u003c\/h2\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eMXG Strada med vejikoner er et af de mest anvendte instrumentbrætdisplays på veje verden over. MXG 1.3 Strada har en 7\" TFT-farvedisplay, der giver en fantastisk visuel effekt. Du kan konfigurere instrumentbrættet til at vise alle oplysninger fra bilens ECU, analoge\/digitale indgange, foruddefinerede matematiske kanaler og et valgfrit GPS-modul.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv id=\"shopify-section-template--17916592291942__rich_text_3kEhi6\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e  \u003cdiv class=\"section  section--padding section--divider\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e  \u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e  \u003cdiv class=\"flex flex-col items-center gap-4\"\u003e  \u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eNem forbindelse\u003c\/strong\u003e\u003c\/h2\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eMXG 1.3 Strada fås med et udvalg af tilslutninger. Vælg enten OBDII eller K-Line CAN, afhængigt af om du vil tilslutte til bilens ECU eller OBDII-port eller direkte til ECU'en via CAN-kanalen.\u003c\/p\u003e  \u003cp\u003eDu kan sample og vise snesevis af kanaler direkte fra ECU'en med kun 2 kabelforbindelser til ECU'en i stedet for flere forbindelser til analoge sensorer. De samplede data afhænger af den faktiske ECU, men vil typisk omfatte omdrejningstal, gasspjældsposition (TPS), olie, luft, vandtemperatur, olietryk, batterispænding, hastighed, gear og lambdaværdi (luft\/brændstofforhold). Listen over tilgængelige ECU-drivere er over 1.000 og opdateres konstant.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv id=\"shopify-section-template--17916592291942__rich_text_cy4Jzy\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e  \u003cdiv class=\"section  section--padding section--divider\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e  \u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e  \u003cdiv class=\"flex flex-col items-center gap-4\"\u003e  \u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eDigitale udgange\u003c\/strong\u003e\u003c\/h2\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eMXG 1.3 Strada har en 1-AMP digital udgang, der kan konfigureres til at blive aktiveret\/deaktiveret afhængigt af værdien af ​​de analoge\/digitale indgange eller af impulserne fra bilens ECU. Dette giver dig mulighed for automatisk at køre eksterne systemer, såsom at tænde\/slukke ekstra lys, for at aktivere\/deaktivere en køleventilator eller cirkulationspumper, når en bestemt hændelse indtræffer.\u003c\/p\u003e  \u003cp\u003eMed CAN-udgang kan du sende beskeder direkte til et eksisterende CAN-netværk for at forbedre mulighederne for bilstyring.\u003c\/p\u003e  \u003cp\u003eTo analoge kameraindgange er også tilgængelige, så du kan skifte din skærm til en\u003cspan\u003e  \u003c\/span\u003e\u003ca href=\"https:\/\/www.aimshop.com\/products\/aim-mirror-reversing-camera-for-mx-series-pdm\" title=\"Aim Mirror \u0026amp; Reversing Camera for MX Series \u0026amp; PDM\"\u003espejlkamera\u003c\/a\u003e, via en trykknapkommando eller hændelsesstyring. Kameraet sælges separat.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv id=\"shopify-section-template--17916592291942__rich_text_E8RKHy\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e  \u003cdiv class=\"section  section--padding section--divider\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e  \u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e  \u003cdiv class=\"flex flex-col items-center gap-4\"\u003e  \u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eDisplay med vejikoner\u003c\/strong\u003e\u003c\/h2\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eMXG 1.3 Strada har en 7\" TFT-farvedisplay med høj kontrast. Den visuelle kvalitet optimeres af omgivelseslyssensoren, som holder baggrundsbelysningen på de bedste lysstyrkeniveauer.\u003c\/p\u003e  \u003cp\u003eVejikoner giver dig mulighed for at anvende betingelser på LED-ikonerne, f.eks. brændstof, motor, olie, lys, indikation og mere.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv id=\"shopify-section-template--17916592291942__rich_text_nAJYLi\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e  \u003cdiv class=\"section  section--padding section--divider\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e  \u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e  \u003cdiv class=\"flex flex-col items-center gap-4\"\u003e  \u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eForkonfigurerede sider\u003c\/strong\u003e\u003c\/h2\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eMXG 1.3 Strada viser omdrejningsskalaen og alle de data, du har brug for, såsom hastighed, vandtemperatur og olietryk, omgangstider og meget mere. Du kan tilpasse siderne, så de passer til dine behov, inklusive op til fire ekstra felter. Definer, hvilke data der vises, med skalaens slutning og måleenheder. Det er nemt at skifte mellem siderne; brug blot trykknapperne.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv id=\"shopify-section-template--17916592291942__rich_text_9enpXA\" class=\"shopify-section tab-controlled-section is-visible initial-reveal\"\u003e  \u003cdiv class=\"section  section--padding section--divider\"\u003e  \u003cdiv class=\"page-width relative\"\u003e  \u003cdiv class=\"collage collage-small with-richtext grid items-start\"\u003e  \u003cdiv class=\"title-wrapper leading-none gap-4 lg:gap-8 flex flex-col text-left md:items-end md:flex-row md:justify-between relative z-1\"\u003e  \u003cdiv class=\"flex flex-col items-center gap-4\"\u003e  \u003ch2 class=\"heading title-sm\"\u003e\u003cstrong\u003eFleksibelt skiftelys \u0026Alarmer\u003c\/strong\u003e\u003c\/h2\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003cdiv class=\"rich-text  md:text-left text-center relative z-1\"\u003e  \u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e  \u003cp\u003eDe 10 flerfarvede RGB-skiftelys kan tilpasses efter din smag og definerer omdrejningstærsklen på analoge eller digitale indgange, ECU-værdier, udvidelsesværdier, matematiske kanaler eller valgfri GPS-mulighed. Du kan vælge betingelser og farver, vælge en konstant arm eller en blinkende arm samt blinkfrekvensen. Du kan også konfigurere en ledsagende tekstbesked og indstille alarmprioriteterne.\u003c\/p\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003c\/div\u003e  \u003ch2 class=\"LandingPage-CatTitle\"\u003e  \u003cbr\u003e\u003cbr\u003e  \u003c\/h2\u003e","brand":"AiM Car","offers":[{"title":"Default Title","offer_id":39443927728230,"sku":"MXG-S-I-OBDII-XA8MXGST12I020","price":1285.0,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/product_mxg_strada_road_00_1.5x.webp?v=1772794418","url":"https:\/\/www.aimshop.com\/da\/products\/aim-mxg-strada-7-tft-car-dash-display-with-road-ikoner-3","provider":"AimShop.com","version":"1.0","type":"link"}
