Springe
Log ind
Søg her
Søg her Log ind Indkøbskurv 0
Indkøbskurv
Din indkøbskurv er tom
  • Fortsætte med at handle
    Skriv din besked
    I alt
    Se indkøbskurv
    Søg her
    Aim SmartyCam 7-Pin External Power Cable - AimShop.com
    SM-EXP
    Aim SmartyCam 7-bens eksternt strømkabel
    Skynd dig, kun 15 varer tilbage på lager!
    £40.00
    • Del på facebook
    • Del på WhatsApp
    • Del på e-mail
    • Facebook Del på facebook
    • WhatsApp Del på WhatsApp
    • E-mail Del på e-mail
    £40.00
    Aim SmartyCam External Power Harness
    The Aim SmartyCam GP HD 2.1 & 2.2 external power harness can be used to be connected to an external battery.
    Suitable for all SmartyCam  External power cable 12V
    712 - 7 pins connector Two free wires
    The Aim SmartyCam external power harness can be used to be connected to an external battery.
    The power lead fits the SmartyCam and the two un-terminated free wires will connect to a 12V battery.
    The cable length is 2m.
    • SmartyCam External Power Harness
    • Allows external battery connection 12V
    • 712 - 7 pin male connection
    • Cable length: 2m
    • 1 x SmartyCam External Power Harness
    • Opdater siden
    • Åbn i et nyt vindue
